Dragon Utility
chrispoacher
Dragon Utility
Post by chrispoacher »
Hi, does anyone have a .cas image of AutoRunII by Datacom Publications? I used to use this a lot back in the day but couldn't for the life of me remember what it was called or who made it. after a bit of net research after years of it bugging me, I knew it was called autorun something but no idea who produced it. :)
Chris.
munkeyboy
Re: Dragon Utility
Post by munkeyboy »
This was on a tape from Preston Computer Games with a copyright of '88 on the cassette label, but the loading screen states that it is from Datacom with a copyright of '85.
It loads with Cloadm.
Gareth
Autorun 2.cas
(5.53 KiB) Downloaded 721 times
chrispoacher
Re: Dragon Utility
Wow that is brilliant, thankyou so much. :)
Had a quick look but failed to write a test screen to a .cas file, probably somthing obvious I'm missing no doubt as its 3am, lol.
Chris.
munkeyboy
Re: Dragon Utility
Post by munkeyboy »
I'm glad it is the one you were looking for. If you have no joy with the cas file then let me know and I will upload the wav.
Gareth
chrispoacher
Re: Dragon Utility
I'm sure it will be fine, I need to refresh myself on the -tapehack xroar option to write out the data to a cas file as I haven't used it for a while. I will let you know how I get on. Chris.
