BASIC code editor...
Does anyone knowns a good BASIC code editor for linux/windows with this features:
* automatic line numbering / renumbering lines
* variable unique checking
Re: BASIC code editor...
Now, DragonPy is usable as a rudimentary BASIC IDE :P
With the updates from today: https://github.com/jedie/DragonPy/compa ... ...ce12148 the Editor is usable and send to emulator and back works fine.
Also the "renumbering" seems to work as expected...
First missing thing is a "Auto invert shift" solution, so you must not use shift to insert uppcase characters... As in DragonPy Emulator. Just type and use shift to make lowercase characters...
Currently it looks like this:
To give it a try:
# clone the repro:
~$ git clone https://github.com/jedie/DragonPy.git
# Alternative download as .zip: https://github.com/jedie/DragonPy/archive/master.zip
~$ cd DragonPy
# Download all ROM files:
~/DragonPy$ ./download_ROMs.sh
# start with Dragon 32 ROM:
~/DragonPy$ python2 ./Dragon32_test.py
Use "BASIC editor / open" in the main menu to open the editor.
You can load/save ASCII .bas files from you local drive or just type a BASIC listing ;)
With "inject into DragonPy" you send the current listing from the Editor to the Emulator and with "load from DragonPy" back from emulator to editor.
Note: The is currently no "warning" that un-saved content will be "overwritten" and there is no "auto-backup" ;)
The "renumbering" tool can be found in the editor window under "tools"
(Currently only the "Dragon 32" ROM worked with the editor)
With the latest commits from today, it also worked now with CoCo Color BASIC 1.3...
Just start: /path/to/DragonPy$ ./CoCo_test.py
New Updates to the BASIC editor in DragonPy:
To run the BASIC Editor without the Emulator:
...path/to/DragonPy$ DragonPy_CLI.py editor
A rudimentary BASIC source code highlighting is available and looks like this:
Special feature: The Line number that are used in GOTO, SOGUB etc. are extra marked on the left side.
Currently the code are only differate into:
* DATA
* Strings
* Comments
* Code
TODO: parse the code, to coloring it differently.
With https://github.com/jedie/DragonPy/commi ... 9bcd5ad9a6 i use http://pygments.org/ syntax highlighter.
Looks like this:
