BASIC: byte value to bits...
1 GOTO 100
5 ' CREATE BITS
10 DIM BI(9)
20 TMP = BY
30 FOR BP = 7 TO 0 STEP -1
40      BV = INT(2 ^ BP)
50      IF TMP>=BV THEN TMP=TMP-BV : BI(BP)=1 ELSE BI(BP)=0
60 NEXT BP
70 RETURN
99 ' START
100 INPUT "START BYTE:";BY$
105 IF BY$ = "" THEN 170 ELSE BY=VAL(BY$)-1
110 FOR X = 1 TO 14
120     BY = BY + 1
130     GOSUB 20
140     PRINT BY;BI(7);BI(6);BI(5);BI(4);BI(3);BI(2);BI(1);BI(0)
150 NEXT X
160 GOTO 100
170 PRINT "BYE"
It worked. But it's very slow :(
Any hints and tips to make is faster or something else?
Rink
Re: BASIC: byte value to bits...
Post by Rink »
I have a thread on this somewhere, it started with me complaining about the lack of shift operators in Dragon BASIC.
How about borrowing a recently discussed technique?
10 FOR V=0 TO 255
20 PRINT CHR$(48-((V AND 128)=128));CHR$(48-((V AND 64)=64));CHR$(48-((V AND 32)=32));CHR$(48-((V AND 16)=16));CHR$(48-((V AND 8)=8));CHR$(48-((V AND 4)=4));CHR$(48-((V AND 2)=2));CHR$(48-((V AND 1)=1))
30 NEXT V
There is an error in line 20 of your program. It should be as follows.
1 CLS:GOTO 100
5 ' CREATE BITS
10 DIM BI(9)
20 TMP = PEEK(BY)
40 BV = INT(2 ^ BP)
60 NEXT BP
70 RETURN
99 ' START
110 FOR X = 1 TO 15
120 BY = BY + 1
130 GOSUB 20
150 NEXT X
160 GOTO 100
170 PRINT "BYE"
jedie wrote: It worked. But it's very slow :(
The following code is faster.
10 CLS
20 LINE INPUT"START ADDRESS (HEX) >";M$
30 IF M$="" THEN 10
40 M=VAL("&H"+M$):E$=CHR$(10):X=0:FOR L=1TO15
50 IF M+X=65536 THEN M=0:X=0
60 P$="":A$=HEX$(M+X):T=PEEK(M+X):IF LEN(A$)<4 THEN FOR Z=1TO 4-LEN(A$):P$=P$+"0":NEXT Z
70 B7=0:IF T=>128 THEN B7=1:T=T-128
80 B6=0:IF T=>64 THEN B6=1:T=T-64
90 B5=0:IF T=>32 THEN B5=1:T=T-32
100 B4=0:IF T=>16 THEN B4=1:T=T-16
110 B3=0:IF T=>8 THEN B3=1:T=T-8
120 B2=0:IF T=>4 THEN B2=1:T=T-4
130 B1=0:IF T=>2 THEN B1=1:T=T-2
140 B0=T:PRINT P$;A$;" ";B7;B6;B5;B4;B3;B2;B1;B0;E$:X=X+1:NEXT L
150 GOTO20
ZEPHYR-BITS1.zip
(506 Bytes) Downloaded 304 times
JEDIE-BITS2.zip
(452 Bytes) Downloaded 290 times
Thanks! Yes, it's faster. But why?
Are Arrays slow?
My test script looks now:
120 CLS
130 LINE INPUT "START ADDRESS (DEZ) >";BY$
140 IF BY$ = "" THEN 1000
145 BY=VAL(BY$)
146 IF BY<0 OR BY>255 THEN 120
150 CLS
160 FOR X = 1 TO 15
180 ' CREATE BITS
190 T = BY
200 B0=0:B1=0:B2=0:B3=0:B4=0:B5=0:B6=0:B7=0
210 IF T=>128 THEN B7=1:T=T-128
220 IF T=>64 THEN B6=1:T=T-64
230 IF T=>32 THEN B5=1:T=T-32
240 IF T=>16 THEN B4=1:T=T-16
250 IF T=>8 THEN B3=1:T=T-8
260 IF T=>4 THEN B2=1:T=T-4
270 IF T=>2 THEN B1=1:T=T-2
280 IF T=>1 THEN B0=1:T=T-1
290 PRINT RIGHT$(" "+STR$(BY),3);":";B7;B6;B5;B4;B3;B2;B1;B0
300 BY = BY + 1
310 IF BY>255 THEN BY=0
320 NEXT X
330 GOTO 130
1000 PRINT "BYE"
The following method is slightly faster than my original code.
Hexadecimal example
10 CLS
30 IF M$="" THEN 10
70 B7=0:IF T AND 128 THEN B7=1
80 B6=0:IF T AND 64 THEN B6=1
90 B5=0:IF T AND 32 THEN B5=1
100 B4=0:IF T AND 16 THEN B4=1
110 B3=0:IF T AND 8 THEN B3=1
120 B2=0:IF T AND 4 THEN B2=1
130 B1=0:IF T AND 2 THEN B1=1
140 B0=T AND 1:PRINT P$;A$;" ";B7;B6;B5;B4;B3;B2;B1;B0;E$:X=X+1:NEXT L
150 GOTO20
Decimal example
10 CLS
20 LINE INPUT"START ADDRESS (DEC) >";M$
30 L=LEN(M$):IF L<1 OR L>5 THEN 10
40 FORI=1TOL:M=ASC(MID$(M$,I,1)):IF M<48 OR M>57 THEN 10 ELSE NEXT
50 M=VAL(M$):IF M<0 OR M>65535 THEN 10
60 E$=CHR$(10):X=0:FOR L=1TO15
70 IF M+X=65536 THEN M=0:X=0
80 P$="":M$=STR$(M+X):A$=RIGHT$(M$,LEN(M$)-1)+"  ":T=PEEK(M+X):IF M+X <10000 THEN FOR Z=1TO 6-LEN(M$):P$=P$+"0":NEXT Z
90 B7=0:IF T AND 128 THEN B7=1
100 B6=0:IF T AND 64 THEN B6=1
110 B5=0:IF T AND 32 THEN B5=1
120 B4=0:IF T AND 16 THEN B4=1
130 B3=0:IF T AND 8 THEN B3=1
140 B2=0:IF T AND 4 THEN B2=1
150 B1=0:IF T AND 2 THEN B1=1
160 B0=T AND 1:PRINT P$;A$;B7;B6;B5;B4;B3;B2;B1;B0;E$:X=X+1:NEXT L
170 GOTO20
ZEPHYR-BITS2.zip
(488 Bytes) Downloaded 305 times
ZEPHYR-BITS2-DEC.zip
(554 Bytes) Downloaded 291 times
Yes, looks good!
The following method is now considerably faster than my original code. The .CAS files are attached.
Hexadecimal example
10 CLS
30 IF M$="" THEN 10
70 PRINT P$;A$;" ";SGN(T AND 128);SGN(T AND 64);SGN(T AND 32);SGN(T AND 16);SGN(T AND 8);SGN(T AND 4);SGN(T AND 2);(T AND 1);E$:X=X+1:NEXT L
80 GOTO20
Decimal example
10 CLS
90 PRINT P$;A$;SGN(T AND 128);SGN(T AND 64);SGN(T AND 32);SGN(T AND 16);SGN(T AND 8);SGN(T AND 4);SGN(T AND 2);(T AND 1);E$:X=X+1:NEXT L
100 GOTO20
ZEPHYR-BITS3.zip
(405 Bytes) Downloaded 291 times
ZEPHYR-BITS3D.zip
(472 Bytes) Downloaded 303 times
Rink
Post by Rink »
Hahahah. Is this becoming a bit of an obsession for you mate? :)
Great work though.
Rink wrote:Hahahah. Is this becoming a bit of an obsession for you mate? :)
Great work though.
Thanks! :)
