Your Computer magazine online
This is maybe old news for some, but while looking for something else I discovered most issues of Your Computer are scanned and available in the big brother archive.org: http://archive.org/details/your-computer-magazine
This was one of the few magazines I could get hold of in my childhood, and a source for hours and hours of typing in Dragon listings. Maybe we can make some kind of index of its Dragon articles?
For instance:
Dragon Explorer - http://archive.org/stream/your-computer ... 1/mode/2up
6809 Dragon Express - http://archive.org/stream/your-computer ... 2/mode/1up
Sky Shield - http://archive.org/stream/your-computer ... 4/mode/1up
Dragon 64 (review) - http://archive.org/stream/your-computer ... 9/mode/2up
The Wall - http://archive.org/stream/your-computer ... 0/mode/1up
Lower Case - http://archive.org/stream/your-computer ... 2/mode/1up
Dragon Interceptor - http://archive.org/stream/your-computer ... 3/mode/2up
Soft Keys - http://archive.org/stream/your-computer ... 5/mode/2up
Hi-Res Colour (Frogsy) - http://archive.org/stream/your-computer ... 1/mode/2up
Convoy - http://archive.org/stream/your-computer ... 5/mode/2up
Sprites - http://archive.org/stream/your-computer ... 4/mode/1up
Gobbler - http://archive.org/stream/your-computer ... 3/mode/2up
Editor and Assembler - http://archive.org/stream/your-computer ... 7/mode/2up
Dragon Kart - http://archive.org/stream/your-computer ... 1/mode/2up
Dragon Animator - http://archive.org/stream/your-computer ... 6/mode/1up
Snaky - http://archive.org/stream/your-computer ... 9/mode/1up
Dragon Forth - http://archive.org/stream/your-computer ... 0/mode/1up
Disco Lights - http://archive.org/stream/your-computer ... 4/mode/1up
Dragon Files - http://archive.org/stream/your-computer ... 4/mode/1up
Tanks - http://archive.org/stream/your-computer ... 9/mode/2up
Graphs and Statistics - http://archive.org/stream/your-computer ... 4/mode/1up
Screen Expander - http://archive.org/stream/your-computer ... 0/mode/1up
Re: Your Computer magazine online
World of Spectrum hosts a large number of magazines (ftp) and books (also available under ftp). Many of the magazines and some of the books are multi-format.
tormod wrote:Dragon Kart
I might have typed this in all those years ago. I will have to check if I still have it on tape. And the Flight Simulator I definitely have on tape because I couldn't face typing it all in so I bought the cassette, plus I made a CAS file of the program many moons ago (will upload if I haven't already).
I remember typing in "Gobbler" from above. It must have been the largest blob I ever entered. More than 6 KB.
Before anyone start typing in from those PDFs :) I have so far found Convoy, Forth, The Wall, Editor and Assembler, Frogsy and Gobbler on my tapes. I will post CAS files as I go through them.
Dragon Forth by B.Watson. From Your Computer July 1984. Comes in two files FORTH (program) and FWORDS (base word definitions).
It seems that I made an autorun loader, so both files are M/L. The copyright notice on the loader splash screen clearly only covers the loader itself ;)
EDIT: The autoloader code is at the end of the BASIC program, so I guess my copyright notice simply covers the splash screen itself :) Must have felt like a real professional sprinkling my own copyright statements on programs that I typed in :oops:
FWORDS.CAS
Base word definitions
(1.63 KiB) Downloaded 530 times
FORTH.CAS
Dragon Forth by B.Watson (BASIC but wrapped in a M/L autorun loader)
(7.46 KiB) Downloaded 502 times
Convoy by Vince Cockett. From Your Computer April 1984.
CONVOY.cas
BASIC
(83.3 KiB) Downloaded 489 times
The Wall by T.Fiers. From Your Computer January 1984. Two parts, BASIC loader/launcher and M/L program.
WALL.CAS
M/L routines
(2.23 KiB) Downloaded 474 times
THEWALL.CAS
Loader/main program (BASIC). Loads "WALL".
(2.53 KiB) Downloaded 476 times
Gobbler (Revenge of PAC MAN) by Tom F. A. Fiers. From Your Computer May 1984.
Two parts, first PACSCRN, then PACMAN:
PCLEAR8:CLEAR100,26000:CLOADM:CLOADM:EXEC26000
PACMAN.CAS
Main (M/L)
(7.29 KiB) Downloaded 482 times
PACSCRN.CAS
Loader/launcher (M/L)
(3.6 KiB) Downloaded 533 times
Frogsy by Vince Cockett. From Hi-Res Colours article in Your Computer March 1984. Three parts, CLOAD and RUN the first BASIC part to load the other M/L parts.
FROGSY3.CAS
Picture (M/L)
(6.67 KiB) Downloaded 521 times
FROGSY2.CAS
M/L routines
(1.26 KiB) Downloaded 531 times
FROGSY.CAS
BASIC
(4.8 KiB) Downloaded 490 times
devo
Post by devo »
Postby tormod » Sat Oct 05, 2013 12:08 pm
I have a question about creating new words with FORTH.CAS. After load and run I follow what I thought was a standard Forth approach and enter:
>: TEST ( with a space between the ':' and 'TEST' then press return to continue the word definition on the next lines)
> BAD LINE ( comes up as an error)
The only way a word has been accepted is by entering on one line:
>:TEST; ( with ';' to terminate and no spaces). I had expected that I could have entered the rest of the word definition on the following lines with a final line terminating it with a ';'.
The command *VLIST shows the word added to the bottom of the list but as 'TEST;' i.e. with the semi-colon, to show 42 words in total.
I've examined the BASIC code but still can't figure out how to create a new word. Any ideas please?
