Exist there somewhere a memory hex viewer? If not, i will start to implement this in BASIC: Simply PEEK the memory and display it with as HEX code...
(Don't know if i can simply PEEK everywhere... Maybe i must exclude some special areas?)
Memory Hex viewer ?
Memory Hex viewer ?
Re: Memory Hex viewer ?
There's a hex editor in DREAMBUG although it's a bit clunky. PC-Dragon emulator has the facility built-in.
You can effectively PEEK anywhere although I/O requires prior setup. If you're simply interested in RAM and ROM then PEEKing any mapped address is straightforward.
DEMON by Compusense is a monitor that can switch between hex and ASCII memory display. The manual is available on the forum (as is the ROM image, though this can also be found in the downloads archive).
I wrote a BASIC monitor program back in the eighties which I used a lot for entering machine code and debugging, but I will need to rescue it from some old tapes if anyone is interested.
There is also a simple machine code monitor program used as an example in the "Inside the Dragon" book. I copied it from the PDF and fixed it up, see attached the compiled binary in CAS format.
monitor.cas- From "Inside the Dragon" (M/L)
- (534 Bytes) Downloaded 768 times
Would be great if you can do that.tormod wrote:I wrote a BASIC monitor program back in the eighties which I used a lot for entering machine code and debugging, but I will need to rescue it from some old tapes if anyone is interested.
I started a BASIC hex viewer. Sourcecode is here: https://github.com/jedie/PyDragon32/blo ... view01.bas
- hex_view01.png (13.23 KiB) Viewed 13048 times
Sounds interesting!tormod wrote:I wrote a BASIC monitor program back in the eighties which I used a lot for entering machine code and debugging, but I will need to rescue it from some old tapes if anyone is interested.
Here is my old BASIC monitor program. Not rocket science but small and handy. See the listing for commands, main ones are DPxxxx to start dumping/editing memory at address xxxx (enter ''' to get out again) and JPxxxx to jump there.
EDIT: Found a newer version called TOOLKIT that also has a disassembler integrated.
TOOLKIT2.CAS- Monitor and disassembler (BASIC)
- (9.98 KiB) Downloaded 860 times
monit4.cas- BASIC monitor/hex entry program
- (3.5 KiB) Downloaded 812 times
