The link to http://searle.hostei.com/grant/6809/Simple6809.html from the origin thread viewtopic.php?f=5&t=2797&p=9027#p9027 is very interesting...
Is here anyone how like to build it together?
It would be great to create a layout for a PCB and produced a small batch series... Seems that there are many companies: http://www.mikrocontroller.net/articles ... hersteller (de)
I have no experience with e.g. eagle. But i can build a 3D Model of a PCB housing.
I do not check if all parts are easy to buy. That is of course a requirement.
It makes IMHO sense to create http://searle.hostei.com/grant/MonitorK ... index.html too.
DIY simple 6809 ???
DIY simple 6809 ???
Re: DIY simple 6809 ???
Other 6809 homebrew project: http://www.msarnoff.org/projects/6809/
The URL looks familiar - is this not the guy who sells all the parts you need in one pack on eBay? Think I bought an MSX pack off him just because it was cheap and looked interesting. Never actually made the machine.
It wiuldn't be too hard to draw out a PCB for this. If I wasn't on a self-imposed ban on starting new projects then I might have given it a go.
If you wanted to try making a PCB yourself then Fritzing is a good tool and is a lot easier to use than Eagle etc. Lacks some of the flexibility and power but more than makes up for it with a great UI.
You mean http://fritzing.org/ ?Rink wrote:If you wanted to try making a PCB yourself then Fritzing is a good tool and is a lot easier to use than Eagle etc.
Looks interesting: http://www.youtube.com/watch?v=Hxhd4HKrWpg
Also interesting:
But last Update Feb.2011
http://www.8bitforce.com/simon6809/SiMon6809 is a 6809 based educational computer.
and the next one: http://laurent68k.free.fr/Site/RedBoard6809.html
EDIT: I collected all projects on the Wiki page http://archive.worldofdragon.org/index. ... Y_Projects
Found another project: Grant's Low-cost FPGA project "MULTICOMP" -> http://searle.hostei.com/grant/Multicomp/
see also: http://freeio.org/2014/02/a-pick-and-mi ... ocomputer/
