Dragon32.com and a new Disk mag?
daftspaniel
Post by daftspaniel »
Hi Folks,
Whilst I was hunting around for Dragon content online, I happened to notice the domain Dragon32.com was available and I could not resist snapping it up :D
I have a few ideas for the site which I would like to bounce off the members of this forum to make sure it makes sense. Firstly, I want to supplement what is already on-line and not be another wiki or archive playing catchup to this great resource! Secondly I'd like to encourage old Dragon keepers to get busy with the old beast again.
Okay so my first solid plan is to get some programming information up there starting with BASIC examples for those getting back to the Dragon who may not have their old collections of books and mags to work from.
I'd also like to float the idea of producing an irregular disk magazine Up2date style. This is to give people a target to work for - so many home projects never get finished due to no deadline. Is this just too crazy an idea for the auld beast ? :lol:
Would be great to know what you think of the plans for the site!
Take care,
Davy
Re: Dragon32.com and a new Disk mag?
Here's a suggested alternative keyboard input routine for continuous movement. This method will also work on the Tandy Color Computer. 'POKE 337,0' in line 40 (which should be omitted for use on the Tandy CoCo) improves keyboard response by enabling rollover for all keys. 'FOR I = 338 TO 345:POKE I,255:NEXT' enables auto-repeating keys by continuously resetting all of the bytes in the keyboard rollover table. I have also modified the screen boundary test in lines 100-130.
10 CLS
20 X=0:Y=0
30 POKE 1024+((Y*32)+X),ASC("*")
40 POKE 337,0:FOR I = 338 TO 345:POKE I,255:NEXT
50 A$ = INKEY$:IF A$ = "" THEN 40
60 IF A$ = CHR$(10) THEN GOSUB150:Y = Y + 1
70 IF A$ = CHR$(94) THEN GOSUB150:Y = Y - 1
80 IF A$ = CHR$(9) THEN GOSUB150:X = X + 1
90 IF A$ = CHR$(8) THEN GOSUB150:X = X - 1
100 IF Y<0 THEN Y=0
110 IF Y>15 THEN Y=15
120 IF X<0 THEN X=0
130 IF X>31 THEN X=31
140 GOTO 30
150 REM HIDE IT!
160 POKE 1024+((Y*32)+X),ASC(".")
170 RETURN
Another (Dragon only) method...
10 CLS
20 X=0:Y=0
40 IF PEEK(342) = 223 THEN GOSUB130:Y = Y + 1
50 IF PEEK(341) = 223 THEN GOSUB130:Y = Y - 1
60 IF PEEK(344) = 223 THEN GOSUB130:X = X + 1
70 IF PEEK(343) = 223 THEN GOSUB130:X = X - 1
80 IF Y<0 THEN Y=0
90 IF Y>15 THEN Y=15
100 IF X<0 THEN X=0
110 IF X>31 THEN X=31
120 GOTO 30
130 REM HIDE IT!
140 POKE 1024+((Y*32)+X),ASC(".")
150 RETURN
daftspaniel
Thanks Steve - appreciate the contribution. I'll get them up there soon ;)
Davy
Feel free to use anything posted by myself in the "Hints and Tips" section on your site. Steve Woolham has also asked me to pass on the same message.
Good luck with the new site! 8-)
The code below is a suggested modification to improve your current example for reading joystick input.
10 CLS
20 PRINT @1, "right joystick"
30 PRINT @32, JOYSTK(0)
40 PRINT @64, JOYSTK(1)
50 RB=PEEK(65280) AND2
60 PRINT @97, "button";RB
70 REM
80 PRINT @161, "left joystick"
90 PRINT @192, JOYSTK(2)
100 PRINT @224, JOYSTK(3)
110 LB=PEEK(65280) AND1
120 PRINT @257, "button";LB
130 GOTO 20
Or this alternative suggestion.
10 CLS
50 RB=1:IF PEEK(65280)AND2 THEN RB=0
70 REM
110 LB=1:IF PEEK(65280)AND1 THEN LB=0
130 GOTO 20
Here's a nice little program which I suggest for your 'Graphics' section. This simple BASIC program demonstrates the use of some HIRES graphic commands, random numbers, and TIMER function.
10 X=RND(-TIMER):Z=0
20 PMODE 3,1:SCREEN 1,Z:PCLS
30 TIMER=0
40 X=RND(256):Y=RND(192):R=RND(20):C=RND(4)
50 CIRCLE(X,Y),R,C
60 PAINT(X,Y),C,C
70 IF TIMER/50 <300 THEN 40
80 IF Z=0 THEN Z=1 ELSE Z=0
90 GOTO 20
daftspaniel
Wow thanks for all the code guys :D
I'll get it on the site as soon as I can.
I particularly like the simplified Joystick code. Still a bit baffled why there is no proper function for buttons :!:
Davy
A few more suggested snippets for your 'Graphics' section.
10 PMODE3,1:SCREEN1,0
20 X=RND(-TIMER)
30 PCLS
40 X=RND(255):IF X=PEEK(1536) THEN 40
50 FOR I=1536 TO 7679:POKE I,X:NEXT
60 GOTO 30
This one is similar to your 'confetti display' program, but on the HIRES PMODE 3 graphics screen.
10 PMODE 3,1:SCREEN 1,0:PCLS
20 X=RND(-TIMER)
30 FOR I=1536 TO 7679:POKE I,RND(255):NEXT
40 GOTO 40
This one is similar to your 'confetti display' program, but on the SEMIGRAPHICS 24 (MODE 24) screen.
10 ' SEMIGRAPHICS 24
20 '
30 PCLEAR 4:SCREEN 0,0
40 POKE65477,0:POKE65475,0:POKE65472,0:POKE65479,0
50 X=RND(-TIMER)
60 FOR I=1536 TO 7679:POKE I,96:NEXT
70 FOR I=1536 TO 7679:POKE I,127+RND(128):NEXT
80 IF INKEY$<>" " THEN 80 ELSE 60
This is the same, but uses the PCLS routine to clear the screen quickly.
20 '
30 PCLEAR 4:PMODE 3,1:SCREEN 0,0
50 X=RND(-TIMER)
60 COCO=38210:DRAGON=43216
70 ROM=DRAGON:IF PEEK(49151)<>180 THEN ROM=COCO
80 POKE 179,224:EXEC ROM
90 FOR I=1536 TO 7679:POKE I,127+RND(128):NEXT
100 IF INKEY$<>" " THEN 100 ELSE 80
NOTE: These four routines are not compatible with DragonDOS (or other). Anyone wanting to try them will need to use one of the free Dos Detach programs, or remove the DOS controller cartridge.
Here are the same four routines with extra code added to make them DOS compatible. These are safe to use on a CoCo or Dragon, with or without DOS.
20 S=PEEK(186)*256+PEEK(187)
30 E=PEEK(183)*256+PEEK(184)-1
40 X=RND(-TIMER)
50 PCLS
60 X=RND(255):IF X=PEEK(S) THEN 60
70 FOR I=S TO E:POKE I,X:NEXT
80 GOTO 50
40 X=RND(-TIMER)
50 FOR I=S TO E:POKE I,RND(255):NEXT
60 GOTO 60
20 '
30 PMODE 4,1:SCREEN 1,0
40 POKE 65314,PEEK(65314)AND7
50 S=PEEK(186)*256+PEEK(187)
60 E=PEEK(183)*256+PEEK(184)-1
70 X=RND(-TIMER)
80 FOR I=S TO E:POKE I,96:NEXT
90 FOR I=S TO E:POKE I,127+RND(128):NEXT
20 '
70 X=RND(-TIMER)
80 COCO=38210:DRAGON=43216
90 ROM=DRAGON:IF PEEK(49151)<>180 THEN ROM=COCO
100 POKE 179,224:EXEC ROM
110 FOR I=S TO E:POKE I,127+RND(128):NEXT
120 IF INKEY$<>" " THEN 120 ELSE 100
daftspaniel wrote:Our first Dragon software project this year is coming along nicely – feeling a bit less rusty and getting used to BASIC again. If anyone has a program for renumbering BASIC on a PC, please let me know. I could code my own but don’t want to reinvent the wheel.
Try the attached MS-DOS based GW-BASIC by Microsoft. GW-BASIC supports load and save (SAVE"PRGNAME",A) in ASCII format.
GW-BASIC.rar
(388.39 KiB) Downloaded 349 times
