Pause BASIC, and wait for key press without using INKEY$
This routine allows you to pause BASIC, and wait for a key press without using the INKEY$ function. The machine code routine is position independent, and DOS compatible. Three bytes ($00D5 - $00D7) are used by the program as follows.
POKE213,0 (default) = Wait for key press
POKE213,1 (or any other value other than zero) = Wait for key press with flashing cursor
POKE214,ASC("Q") = Exit only when the "Q" key is pressed
PEEK(215) = ASCII code of last key pressed
N/B The example program below pokes the machine code into the cassette buffer. It could be overwritten if you were to load a program from cassette. To get round this, simply alter line 80 (CoCo 90) to poke in the machine code anywhere you like.
Dragon
10 'PAUSE V1.0
20 'FOR THE DRAGON 32/64
30 'BY STEPHEN J WOOLHAM
40 '***************************
50 'BASIC EXAMPLE PROGRAM
60 '***************************
70 MC$="0DD52703BDBBB5BDBBE527F40DD6270491D626EC97D739"
80 X=1:FOR I=458 TO 480:POKE I,VAL("&H"+MID$(MC$,X,2)):X=X+2:NEXT
90 EXEC458
CoCo
10 'PAUSE V1.0
20 'FOR TANDY COLOR COMPUTER
30 'MODELS 1, 2, AND 3
40 'BY STEPHEN J WOOLHAM
50 '***************************
60 'BASIC EXAMPLE PROGRAM
70 '***************************
80 MC$="0DD52703BDA199AD9FA00027F30DD6270491D626EB97D739"
90 X=1:FOR I=458 TO 481:POKE I,VAL("&H"+MID$(MC$,X,2)):X=X+2:NEXT
100 EXEC458
