XRoar sound clicks
retrofreak90
XRoar sound clicks
Post by retrofreak90 »
As the topic says, when XRoar is running I can here a constant clicking sound. Any idea what causes this and how to stop it?
Re: XRoar sound clicks
Are you using XRoar-snap-20091207-windows32 ? If not go to viewtopic.php?f=5&t=182&start=20 and download Sixxie's link. The rest of the thread will explain the problem that you describe.
Actually, now that I've checked, I have XRoar-snap-20100119-windows32. If Ciaran (Sixxie) doesn't mind, the current direct link is http://www.6809.org.uk/tmp/xroar/xroar- ... dows32.zip (Ciaran, if you do mind just say so below and I'll remove the link.)
