Problem
coops
Problem
Post by coops »
Has anybody else had trouble getting Trekboer and Crazy Painter, as downloaded from the main site, to work. Seems like all the other ones are fine but these wont load up. Any fixes out there for these two?
Cheers for any help.
PEABODY IS AWAY...
Re: Problem
Yes, there are problems with both of these files.
I've FIXCASed Trekboer (see attachment) so that it now works in XRoar-0.22, but I cannot get Crazy Painter to work, FIXCASed or otherwise. Even XRoar-0.12pre2 (which uses a speed loading routine) cannot load Crazy Painter, so I expect that the file is corrupt.
Fixed_Trekboer.zip
(17.45 KiB) Downloaded 676 times
coops
Re: Problem
Post by coops »
Cheers mate. I'll try that when I get home as im answering this from work (we're busy obviously). It looks like theres quite a few corrupt files on the download page which is a shame but im just grateful for what ive got (which is the majority).
PEABODY IS AWAY...
Re: Problem
I do have a CoCo version of Crazy Painter, here, along with some other CoCo originals. It won't load on a Dragon, but if you're emulating anyway...
coops
Re: Problem
Post by coops »
I might as well hadnt I? Once again, cheers.
PEABODY IS AWAY...
snarkhunter
Re: Problem
Post by snarkhunter »
Looks like "PAINTER.BIN" (extracted to a ".CAS" file from my "ARCAD05B" virtual disk) just won't work in plain "Dragon 32" emulation (tried this in both 0.21 & 0.22 releases, and it crashed every time). I don't have any idea why.
So you will need to run it under "DragonDOS" emulation - works fine under both releases.
1/ Start XRoar
2/ <Ctrl> + 1, then select your "ARCAD05B.vdk" file
3/ LOAD "PAINTER.BIN" <Enter>
4/ RUN "UNBOOT.BIN" <Enter> (wait for the "beep" sound)
5/ EXEC 16384 <Enter>
6/ ... and you're in business again!
Kind regards,
Lionel
PAINTER.cas
(24.76 KiB) Downloaded 629 times
ARCAD05B.vdk
(180.02 KiB) Downloaded 676 times
coops
Re: Problem
Post by coops »
Thankyou very much, I will sort that this weekend when Ive a bit more time.
PEABODY IS AWAY...
Re: Problem
Here's a perfect working copy of the Dragon 32 cassette based version...
PAINTER_D32.zip
(6.45 KiB) Downloaded 686 times
coops
Re: Problem
Post by coops »
Thanks Zephyr, its much appreciated.
(Now someone get me a gun for that bloody dog)
PEABODY IS AWAY...
Re: Problem
Gah, the snake is worse :)
Did that game really load without a title screen on the Dragon version, btw?
