Does anyone know where the latest versions of HDB-DOS can be downloaded ("HDB-DOS 1.4 with DriveWire support" is currently listed in the XROAR 0.29 documentation as part of the ROM lists). I can find v1.1D and 1.3, but not the latest 1.4 version.
Version 1.1D can be downloaded from: http://www.cloud9tech.com/
Version 1.2 can be downloaded from here.
Version 1.3 can be downloaded from: http://roms.coco.l-w.ca/
Version 1.4 (Jan 4th source code update) can be downloaded from here.
Compiled versions of HDB-DOS 1.3 (including DriveWire support) from http://roms.coco.l-w.ca/ are attached to this post.
HDB-DOS
Re: HDB-DOS
Here is the complete build of the HDB-DOS 1.4 roms and wav files.
I have built this set on October 2012, based on the HDBDOS source and make files which are part of the toolshed repository
Complete source files are available here:
http://toolshed.hg.sourceforge.net/hgwe ... ca5/hdbdos
- HDBDOS1.4.zip
- HDBDOS1.4
- (318.54 KiB) Downloaded 516 times
Re: HDB-DOS
Thanks Ken!
Is it possible to download all of the source code files in one .zip (or other) archive?
Re: HDB-DOS
The WAV files for the HDB-DOS rom on this 1.4 package are bad. They give me an IO ERROR after showing the name of the file during loading.
I converted the original BIN files using Cocotape, now they load fine. Unfortunately, I still have the same error using Drivewire on the Color64.
Daniel
Daniel
Re: HDB-DOS
Attached is the latest HDBDOS 1.4 source folder from the toolshed repository as well as the cocoroms source folder which included the ecb_equates which are required to make hdbdos.zephyr wrote: Is it possible to download all of the source code files in one .zip (or other) archive?
Ken
- cocoroms.zip
- Cocoroms source
- (343.89 KiB) Downloaded 542 times
- hdbdos.zip
- HDBDOS 1.4 source
- (74.67 KiB) Downloaded 559 times
Re: HDB-DOS
I fixed the makefile (latest from Mercurial) so the cb_equates and ecb_equates are built correctly. Also, I saw no ROMs are being generated with 38400 baud code for DW. I added a CoCo 1 ROM with that defined. The diff and the ROMs I generated with them are here: http://users.vialink.com.br/jcastro/hdbdosKenH wrote:Attached is the latest HDBDOS 1.4 source folder from the toolshed repository as well as the cocoroms source folder which included the ecb_equates which are required to make hdbdos.zephyr wrote: Is it possible to download all of the source code files in one .zip (or other) archive?
Ken
The makefile doesn't generate a BIN file though, only raw ROM images. Anyone has a script for that?
Re: HDB-DOS
make allRe: HDB-DOS
Here are the HDB-DOS 1.1D and HDB-DOS 1.2 (DriveWire) ROM images and .WAV files. I have tested all of the attached CoCo 1 and CoCo 2 compatible ROM images (and .wav files) with DriveWire 3 and 4. They all worked perfectly.
I recommend using Audacity for making real audio cassette copies from the included wave (.WAV) files.
- HDB-DOS_1.1D_DW.rar
- (33.48 KiB) Downloaded 461 times
- HDB-DOS_1.2_DW.rar
- (33.47 KiB) Downloaded 496 times
Re: HDB-DOS
How do you download files from Mercurial?JCCyC wrote: I fixed the makefile (latest from Mercurial) so the cb_equates and ecb_equates are built correctly.
