The (terrible) J Morrison tape Dragon 4, containing:
- Pterodactyl
- Torpedo Run
- Hornets
http://www.acornelectron.co.uk/Dragon_4_WAV.zip
To load each game:
CLOADM (ENTER)
EXEC 7700 (ENTER)
However, I can't get xRoar to recognise the WAV file.
Pterodactyl and Hornets are available from this archive. But the Torpedo Run CAS doesn't work properly. Hopefully someone can get a CAS from it...!
Dragon 4 (J Morrison)
daelectron
- Dragon 4 Inlay
- Dragon_4_000.jpg (1.83 MiB) Viewed 3484 times
- Dragon 4 Cassette
- Dragon_4_000.jpg (601.17 KiB) Viewed 3484 times
Re: Dragon 4 (J Morrison)
Currently I can load both Torpedo Run and Hornets but not Pterodactyl in XRoar. However I have a problem with Torpedo Run, after I launch my first torpedo I can no longer move my sub or launch another torpedo, I would like to resolve this issue before making a .cas file.
There's another version of PET later in the tape.
I have the same issue with TORPEDO, need to feed that into a real Dragon and see what changes...
Here is a copy with the problem fixed. A quick disassembly of the routine at $238A (generates sound) and you can clearly see what was causing the problem.
ENJOY!
ENJOY!
- TORPEDO2.zip
- (4.72 KiB) Downloaded 336 times
