Quick assembly question ...
I'm trying to compile some old code of Roy Coates to control a Dragon Claw, and I'm not sure what assembler he was using. I'm seeing lines like this:
LDB 0,X+
Is that the same as:
LDB ,X+
I think it is ... but I'd like to double check before I search and replace this whole file!
Cheers, Tony
Re: Quick assembly question ...
yes, Tony
both will do the same task despite the created code could differ depending on the assembler you use.
