Question on Opcode behaviour
Hello, dear friends!
I was tinkering with the MAME disassembler and noticed something interesting.
This is a regular DEC opcode:
7a ff 00        DEC    $FF00
And this is technically the same opcode, but it's prefixed by the page 2 opcode:
10 7a 09 00     DEC    $0900
But there's no opcode $7a on page 2. So, what does the processor do? Look on page 1? Panic? :mrgreen:
Would it work the same with a page 3 prefix ($11), or would it look on page 2 and then page 1?
tlindner
Re: Question on Opcode behaviour
Post by tlindner »
I originally wanted to disassemble the mnemonics a little differently, but I couldn't get buy in from the other MAMEDevs.
10 7a 09 00           DEC_2      $0900
10 11 7a 09 00        DEC_23     $0900
10 11 10 7a 09 00     DEC_232    $0900
Very interesting!
I was making a simple disassembler for fun and using MAME's to double check my work. that's when this "inconsistencies" showed up.
Regarding the undefined instructions, I was a bit confused because I didn't know that the 'X' meant indeed undefined and couldn't find any info on them. On mine I've decided for the time being to prefix them with a lowercase 'u' as this clearly breaks the normal naming convention for the opcodes, making them more apparent.
Thanks for the links! There are a lot of details I didn't knew about the 6809.
Hi Tim!
I found your nice 6309 indexed mode postbyte chart (https://tlindner.macmess.org/wp-content ... counts.pdf) and I'd like to ask if it includes the original 6809 postbytes, or if there are some that behave in a different way.
Cheers!
tlindner
Post by tlindner »
The 6309 indexed addressing mode opcodes added to the existing 6809 indexed addressing modes without changing how the 6809 codes worked.
Niiiiiice!
Then your table is going to be very handy :mrgreen:
Thank you very much!
Hi Tim!
I'm going through your table and noticed that postbyte $8A (F,X) is marked as having another byte following it, while $AA (F,Y) does not.
Is that an actual useless byte that only affects the ,X form or is it a typo in the table?
All other Register,Register combinations don't have any following byte.
I've also noticed (by comparing my disassembly with MAME's) that I'm showing opcode 0xCD as LDQ Immediate (according to the instruction set) while MAME shows:
31f0: cd              XHCF
Could it be that XHCF is used if its prefixed by $10 or $11?
I may have found another error in MAME's disassembler.
0f5b: 10 4a           DECA
0x4A is DECA, but 0x104A is DECD instead.
