Dragon 32 black and white output
brendan1495
Post by brendan1495 »
Hi All,
I am trying to repair a Dragon 32 everything works fine but its in black and white. I have tried changing the pots but still the same, I have also resocketed and changed the LM1889 but no difference. Any ideas were to go from here would be appreciated.
Brendan
Re: Dragon 32 black and white output
Hi Brendan, welcome to the Dragon Archive!
Can you check your motherboard and tell us which part number it has written on it?
brendan1495
This is the board
Ok, according to the service information, this is what you could try:
C. Faulty Colour
1. Adjust RV1 (and RV2 if fitted).
2. Alter value of C7.
3. To obtain full green screen or to cure 'rainbow effect', fit a 2-22 pf capacitor trimmer instead of C7.
4. If colour fault on 22" or 27" SONY sets, then fit 15K resistor across Pin 4 of IC9 to Pin 4 of IC10.
5. Change IC9.
6. Change IC16.
7. Change IC12.
Are you connecting it to an old TV, new TV or to a capture device?
And check your voltages! Other way around, but I accidentally powered a D64 from a D32 PSU board before which led to no proper -5V and the most obvious symptom was no colour (and tbf pretty shonky video generally, but it was there).
That's a good thing to check!
Brendan, do you mind taking pictures of both sides of the power board?
brendan1495
At work at the moment will do when I get home
brendan1495
sixxie wrote: Tue Mar 25, 2025 9:54 am And check your voltages! Other way around, but I accidentally powered a D64 from a D32 PSU board before which led to no proper -5V and the most obvious symptom was no colour (and tbf pretty shonky video generally, but it was there).
Will check, thanks
brendan1495
robcfg wrote: Tue Mar 25, 2025 9:15 am Ok, according to the service information, this is what you could try:
C. Faulty Colour
5. Change IC9.
6. Change IC16.
7. Change IC12.
cnnecting to crt
brendan1495
robcfg wrote: Tue Mar 25, 2025 10:12 am That's a good thing to check!
I have modified the power board to use a meanwell, works fine on my other Dragon
