CLOAD Auto-Run program for CoCo
CLOAD Auto-Run v2.0
The "CLOAD Auto-Run" (CCARxx) program enables auto-running of BASIC programs loaded with the CLOAD command.
Two versions of the program are included: "CCARLO" (locates to low RAM) and "CCARHI" (locates to high RAM). Both versions are DISK BASIC 1.1 compatible. I recommend using "CCARLO" unless it fails due to incompatibility issues with other DOS variants or other cartridge based software that you normally like to keep attached.
The program requires a 32K or 64K Tandy TRS-80 Color Computer with Extended Color BASIC.
The included wav files (CCARxx.wav) were created by using Sarah Burgin's Dragon Convert (DC.exe).
Link to the Dragon version viewtopic.php?f=7&t=11223&p=25743#p25743
CoCo CLOAD Auto-Run v2.0 By Steve Evans (Zephyr).zip
(5.61 KiB) Downloaded 849 times
