DragonDOS 64
DragonDOS 64
DragonDOS 64 v1.0
DragonDOS 64 Is a copy of DragonDOS 1.0 that I have modified to operate entirely in 64K (MAP1) mode. It is designed to operate most reliably on a Dragon 32 or 64 with a BASIC System ROM that has been patched with my ROM (in RAM) Reset Patch.
DragonDOS 64 does not use any of the BASIC graphics page memory.
To install DragonDOS 64 from the included (vdk) floppy disk:
Enter RUN"LOADER"
To install DragonDOS 64 from cassette:
You will need to download my Cartridge Disable (DCARD) and ROM (in RAM) Reset Patch (DRAGONRP) programs. Then follow the step-by-step instructions below.
(1) Enter CLOADM"DCARD":EXEC to disable DOS with Cartridge Disable.
(2) Enter CLOADM"DRAGONRP":EXEC to apply the ROM (in RAM) Reset Patch.
(3) Enter CLOADM"DDOS64":EXEC to install DragonDOS 64.
Link to my Cartridge Disable post viewtopic.php?f=7&t=11236
Link to my ROM (in RAM) Reset Patch post viewtopic.php?f=7&t=11230
DragonDOS 64 v1.0 By Steve Evans (Zephyr).zip
(38.01 KiB) Downloaded 258 times
Re: DragonDOS 64
I have added a (much needed) paged directory listing feature to DragonDOS 1.0 and DragonDOS 64 V1.0. Press either BREAK or LEFT ARROW key to exit from pause mode. Press any other key to display the next page.
DragonDOS 1.0 and 64 v1.0 (with Paged Listing feature).zip
(428.15 KiB) Downloaded 294 times
Re: DragonDOS 64
I have written a separate add-on paged directory listing program that provides a paged directory listing feature for DragonDOS 1.0, DragonDOS 64 V1.0, DragonDOS NX01, and DragonDOS 64 NX01.
Link to my paged directory listing program viewtopic.php?f=7&t=11242
New (February 10th) DOSPlus 4.9B version viewtopic.php?f=7&t=11244
