New CLOAD Auto-Run program
CLOAD Auto-Run (CARxx) v1.0
The "CLOAD Auto-Run" (CARxx) program enables auto-running of BASIC programs loaded with the CLOAD command.
The program requires a Dragon 32 or a Dragon 64 running in 32K mode. It is DragonDOS compatible, and does not need 64K of RAM to enable the CLOAD auto-run feature.
The included wav files (CARxx.wav) were created by using Sarah Burgin's Dragon Convert (DC.exe).
CLOAD_Auto-Run_v1_By_Steve_Evans-(zephyr).zip
(7.28 KiB) Downloaded 1234 times
Re: New CLOAD Auto-Run program
CLOAD Auto-Run v2.0
The "CLOAD Auto-Run" (DCARxx) program enables auto-running of BASIC programs loaded with the CLOAD command.
Two versions of the program are included: "DCARLO" (locates to low RAM) and "DCARHI" (locates to high RAM). Both versions are DragonDOS 1.0 and DOSPlus 4.9B compatible. I recommend using "DCARLO" unless it fails due to incompatibility issues with other DOS variants or other cartridge based software that you normally like to keep attached.
The included wav files (DCARxx.wav) were created by using Sarah Burgin's Dragon Convert (DC.exe).
Link to the Tandy TRS-80 Color Computer version viewtopic.php?f=7&t=11249
Dragon CLOAD Auto-Run v2.0 By Steve Evans (Zephyr).zip
(5.63 KiB) Downloaded 1062 times
CLOAD Auto-Run 64 v2.0
This version of CLOAD Auto-Run v2.0 is for the Dragon 64 and Dragon 200(E) running the 64K mode BASIC operating system.
Dragon CLOAD Auto-Run 64 v2.0 By Steve Evans (Zephyr).zip
(5.55 KiB) Downloaded 1172 times
