New tool: MPI cartridge copy
bluearcus
Post by bluearcus »
Noddy little disk based tool for copying autostart cartridges using MPI and CoCoSDC or other DragonDOS compatible disk system. For when you don't want to crack open the Cart and read the EPROM, or mess around with masking the *CART line, but do have disk system and MPI available!
Start Dragon with Disk system in MPI and booting as normal, and ROM cartridge in another slot, then run MPICOPY.BAS
MPIcopy.zip
Zip containing DragonDOS VDK disk image and source code.
(15.63 KiB) Downloaded 1237 times
