Copy Text from Xroar
megagarrym
Post by megagarrym »
Hi All
I'm loving the new middle-button paste feature in the latest version of Xroar as I like to code in Notepad++ then paste it in to Xroar, or whatever I'm using. It seems to interpret 1s as lower case Ls, so a few edits are required which is no problem.
Is there a way to copy a BASIC program from Xroar and then paste in to a Windows text editor? Is there any other way to do it, It would be great to be able to print to pdf in xroar or something like that.
Garry
Re: Copy Text from Xroar
Allowing text selections the other way around would be - well, not completely impossible, but probably less useful than it sounds.
For a start, maximum 16 lines at a time. Then how do you determine reliably when a line has ended rather than continued over to the next one?
Anyway, what you could try is running with "-lp-file <filename>" - and using LLIST - then you can "print" to a file (buffered output, flush with control+shift+p). That's my preferred way of getting listings out.
megagarrym
Hi Sixxie
This is brilliant!
I changed my Xroar shortcut to this...
"E:\Software\Emulators\Dragon 32 Emulator\xroar-1.4.1-w64\xroar.exe" -lp-file "C:\temp\printout.txt"
Then I loaded the program I wanted to 'print' and did the LLIST. The file then appeared in the folder as 0kb. I then hit ctrl+shift+p and the file size grew to a mighty 1kb, and I could open it in my text editor.
This is really useful to be able to write a program in a text editor and paste it in and then make minor tweaks in Xroar then get it back in to text editor for further development.
I am now adding you to the long list of people to whom I owe a pint. :D
Garry
