XRoar, How to append to the end of a TAPE file
Hi Ciaran,
I have a tape file that contains two programs and now I need to append four more.
Opening the Tape tool in XRoar allows me to insert a tape file, but when I choose the existing one, it asks me if I want to overwrite it
Of course I don't want to, so I do answer NO and the result is No file attached ...
How could I attach an existent file as an output file so that SAVE write past the end?
thanks in advance
Re: XRoar, How to append to the end of a TAPE file
You're probably alright saying "yes" to that actually - it's badly phrased, but it's a windows/gtk built-in dialog I think. What XRoar will actually do by default is append to the file (you can press "rewind" to overwrite). Which is altering it, but you shouldn't lose data.
I wonder if there's a way of overriding the text windows (or whatever) puts in that dialog...
sixxie wrote: Tue Apr 11, 2023 11:16 am You're probably alright saying "yes" to that actually - it's badly phrased, but it's a windows/gtk built-in dialog I think. What XRoar will actually do by default is append to the file (you can press "rewind" to overwrite). Which is altering it, but you shouldn't lose data.
I had not verified that point, going to answer Yes ...
Will tell you how it goes. Once known the behaviour, it doesn't matter that much the text.
thanks a bunch!
Verified, it works perfectly!
In fact after answering yes one can read the 'already' used time in that tape.
It is not zero, so it has not been rewinded.
