F9DASM
F9DASM
I am using F9DASM to unassemble a CoCo binary file that contains a header (5 bytes)
I am unable to tell F9DASM to skip these 5 header bytes.
I could cut them but I need to work with some more files.
I have not found a usufull param in the help file :-(
Is there any parameter that helps skipping those bytes?
Thanks in advance
Re: F9DASM
as I don't know how to do it, I have downloaded 'dd.exe' for Windows
and have made a batch file to cut the 5 leading bytes of the 13 files
Now time to search for the keyboard decode ...
Re: F9DASM
hah, 'dd' was exactly the first thing i thought about too!
