I am trying to save a basic program and two binary files to a WAV file so that it could be put in a physical tape ...
By now I cannot get anything written to the attached tape (for output)
The command I issue to launch xroar is that one:
xroar -vo sdl -machine dragon64 -extbas d64_1.rom -altbas d64_2.rom -machine-cart dragondos -cart-rom ddos40.rom -force-crc-match -disk-write-back -tape-write "PROVA.WAV" -joy-left 0,0:1:0 -kbd-translate -lp-file ..\XRoar\sortida.txt
![Sad :-(](./images/smilies/icon_e_sad.gif)
With Dragon64 started, I do attach a VDK file from where I do load a basic program, then I issue
CSAVE"RO and press enter. After a while the prompt comes back, but the PROVA.WAV file keeps being zero bytes!
After closing XRoar nothing happens to that file
I would appreciate if you could shine some light on that subject ... I am sure I had done things like that many times in the past ...
Ps I am using XRoar v1.30
