Adventure International (Scott Adams) games
I don't know if these games would be worth to anyone who likes playing text adventures
but, in any case, I am uploading thirteen Scott Adams games (Adventure International)
that I have put individually in virtual VDK files including the loading screen
There are two versions of these games:
- One without lowercase support, so using inverse colours as usual
- Another that supports lowercase from MC6847T1 using its external ROM
These games ask the player if the computer supports true lowercase. Please, ask Y
only in case this is true. I have used them on XRoar by adding a parameter
in the command line that executes XRoar, for instance
- xroar -machine dragon64 -vdg-type 6847t1 ...
Ps To play any game, just issue RUN"RUN
No lowercase.zip
(142.94 KiB) Downloaded 429 times
With lowercase support (for MC6847T1-XRoar).zip
(143.22 KiB) Downloaded 431 times
Re: Adventure International (Scott Adams) games
I forgot to add some screen shots ...
These ones are normal Dragon screenshots (no lowercase suport)
And now a few on XRoar emulating the MC6847T1, so true lowercase
for maybe someone has problems to play one of these games, I am adding here the walkthrough for each one
in a compressed file tagging it as SPOILER
SPOILER-WalkThrough.zip
CAREFULL - CONTAINS SOLUTION
(34.7 KiB) Downloaded 403 times
This is great, thanks a lot Pere!
robcfg wrote: Thu Jul 21, 2022 7:35 pm This is great, thanks a lot Pere!
Hey,
pleased to hear from you again!!
You know I like to share my works, even the smaller ones ;-)
pser1 wrote: Thu Jul 21, 2022 2:21 pm for maybe someone has problems to play one of these games, I am adding here the walkthrough for each one
Don't forget the Classic Adventures Solution Archive which contains solutions, maps, hints, and the "50 bonus points" solution for Ghost Town by little old me!
The Adventureland page is at https://solutionarchive.com/game/id%2C3 ... eland.html, for the others click on the links under Related: Scott Adams Adventures.
Alastair wrote: Thu Jul 21, 2022 10:57 pm [
thanks a lot for this interesting info!
I didn't know
Hi, Alastair
unfortunately I have not been able to download any file from the Adventureland page ... sorry :(
any hint will be very appreciated
thanks
I've had no problem downloading the files, but I've attached them here for you.
Adventureland.zip
(137.75 KiB) Downloaded 410 times
robcfg wrote: Fri Jul 22, 2022 10:40 am I've had no problem downloading the files, but I've attached them here for you.
Thanks a lot, Robert
Not sure if one must register prior to download anything ...
I had not even found the files to be downloaded :-(
I have seen all of them right now, thanks once again!
