AGD converted games - UPDATE for MireMare2
Steve Bamford has found a bug in the control menu for Miremare2. Joystick didn't work at all. Thanks a lot for spotting that one!!
As I said, I decided to add a third option to be able to redefine the keys but this means that the std AGD function called ControlMenu
was no more of use because it only accepts two choices.
Well, once created the new controlmenu, I forgot to update the system control variable that otherwise ControlMenu would have done!
So, I have corrected that behaviour and, if you dare, you can try to play with the Left Joystick ;-)
Besides that, I have been tweaking the tune player so that any tune can be exited just pressing the Break key.
I have put the four virtual disk versions in a zip, so that anyone can update the preferred ones ...
MireMare corrected.zip
(122.79 KiB) Downloaded 754 times
