SuperSprite-FM+ converted AGD games - Pack#01
From time to time I plan to be uploading/publishing small packs (2 to 6 games)
with AGD converted games that work on SuperSprite-FM+ module by John Whitworth.
This is pack #01 and it comes with these games
. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .   UP   DWN  LFT  RGT  F1   F2   F3
Bean Brothers by Dave Hughes (C)2018				'A', 'Q', 'O', 'P', ' ', 'Z', 'I'
Circuitry by John Blythe (C)2017				'Q', 'A', 'O', 'P', ' ', 'Z', 'I'
Diamond Geezer by TommyGun (C)2013	 			'Q', 'A', 'O', 'P', ' ', 'Z', 'I'
Foggy's Quest by John Blythe (C)2017	 			'Q', 'A', 'O', 'P', ' ', 'Z', 'I'
Meteormania by Allan Turvey (C)2018				'Q', 'A', 'O', 'P', ' ', 'Z', 'X'
Robot, the Impossible Mission by Simon Ferré (C)2019 		'Q', 'A', 'O', 'P', ' ', 'U', '5'
DragonV9958-01.zip
(109.56 KiB) Downloaded 551 times
CoCoV9958-01.zip
(106.49 KiB) Downloaded 623 times
V9958-AGD converted Games-INTRODUCTION.TXT
(4.18 KiB) Downloaded 646 times
New virtual disks NAMING SYSTEM for V9958.TXT
(1.35 KiB) Downloaded 642 times
Keys used by V9958 AGD Games v1.1.TXT
(1.09 KiB) Downloaded 619 times
Docs.zip
(2.2 KiB) Downloaded 625 times
Screenshots come in next four messages
Re: SuperSprite-FM+ converted AGD games - Pack#01
First block of ten screenshots
second lot of ten screenshots
third block of ten
and finally these ones
lcurtisboyle
Post by lcurtisboyle »
Pere - just want to doublecheck - these packs will require both the SuperSprite FM+ board AND a 6309 to run? (But only 32K of RAM?)
lcurtisboyle wrote: Sat Feb 12, 2022 5:48 am Pere - just want to doublecheck - these packs will require both the SuperSprite FM+ board AND a 6309 to run? (But only 32K of RAM?)
Hello!
correct, Curtis. The engine has been converted to work with an HD6309 to use double speed without issues in a few parts that
need it to have same speed than the MSX2+ machines with higher clock rates
The Supersprite-FM+ board is required, but you could run these games on MAME emulating any of the 6309 machines, even CoCo3
By now only 32Kb required. But, maybe in the future, I will add music to some games and this requires more and more RAM so,
most probably, music versions will require the whole 64kb
