Serial Numbers
Serial Numbers
Some more serial numbers if of interest:
Re: Serial Numbers
Forgive me if I've missed the point of collecting serial numbers, but found the ones below currently on ebay. Posting images from ebay is probably a no-no but these are the numbers (all d32):
Swansea
033793 DG
057402 DG
Port Talbot
080799 DG
103566 DG
158756 DG
166689 DG
237196 DG
249677 DG
253680 DG
With odds of 'fairly unlikely', 249677 just happens to be immediately before one already in the wiki :)
Re: Serial Numbers
Blimey, you have some early machines! I thought my 003300 was old. Are these from 'back in the day', or more recent purchases? Just intrigued!
Re: Serial Numbers
It was more luck than judgement. I had a d32 & d64 in the 80's, but the others were acquired in the 90's when people were pretty much giving the things away.
Re: Serial Numbers
Think it's better collected to the Wiki ;)
sorchard wrote: Fri Aug 20, 2021 9:07 pm Forgive me if I've missed the point of collecting serial numbers
Maybe we can determine the used "number ranges", divided according to the production site ?!?
But then we would probably need a lot more data.
Re: Serial Numbers
So long as you ignore the spammy nonsense serial numbers you can add the numbers from the survey at http://www.studio68.no/surveys/dragon/default.asp. (Vato has not logged in here since 2017 so it is highly unlikely that the spam entries in the survey will be removed.)
munkeyboy
Re: Serial Numbers
Post by munkeyboy »
The interesting point of the serial number list for me is how many 32's were made in Swansea before going to Port Talbot.
I have a number of Dragons and the serial numbers I have follow the pattern of about 60,000 units being produced in Swansea and any later numbers from Port Talbot, but I have one number that fits in between the Swansea and Port Talbot numbers present in the current list and that is 059553DG from Swansea, which narrows the gap a little.
059553 DG.jpg (52.01 KiB) Viewed 61824 times
Re: Serial Numbers
http://archive.worldofdragon.org/index. ... al_Numbers
This is where they are logged on the WIKI
Re: Serial Numbers
admin wrote: Mon Oct 25, 2021 12:07 pm http://archive.worldofdragon.org/index. ... al_Numbers
Perfect! I add three of my five ones in the Wiki: https://archive.worldofdragon.org/index ... oldid=9815
Here the images, too:
JeeK
Re: Serial Numbers
Post by JeeK »
My Dragon's plate
155244 DG
Port Talbot
Is user jedie adding the numbers to the wiki or are other's allowed to sign up for the wiki to edit the page?
I added my profile to the wiki group, but I still have no access to the wiki (editing pages). I'm not sure what the wiki group membership is meant to be.
