Blockdown (2020)(Teipen Mwnci)
You might want to flag it as by "Seismic Brains" instead - up to you. Includes "original tape sample".
Edit: ok, better disk image included now
Blockdown (2020)(Teipen Mwnci).zip
(1.06 MiB) Downloaded 200 times
Re: Blockdown (2020)(Teipen Mwnci)
HI, Ciaran
just downladed the zip and found that the virtual disk file is in fact a CoCo one (160Kb), not a 40 track disk (180Kb)
When I attach it to a XRoar D64 with Ctrl+1 and then issue BOOT the result is
?BT ERROR
And trying a DIR on it returns error
?IV ERROR
Do you have a VDK file for the Dragon?
Thanks in advance
mounting the DSK on XRoar CoCo2 and issuing DOS doesn't start the game, just returns OK prompt.
But LOADM"BLOCKD":EXEC works flawlessly
Argh, sounds like I included the wrong disk image! I’ll check things out…
Ok, modified the upload in the initial post! I know what I did: I just included a copy of what I'd uploaded to colorcomputerarchive.com, which was just a coco image. Now hybrid, as intended, and should BOOT!
Thank you for spotting this :)
Hi Ciaran,
downloaded it and works flawlessly
thanks a bunch!
