Drivewire4 server problems
I have had a laptop crash. The hard disk has blown and doesn't work anymore.
I have put another disk in its place and restored data and applications from an old backup
But Windows has been installed from scratch, also Java and Netbeans.
I can program and execute Netbeans old applications without issues
But once I start the Drivewire4 server and then do start the Dragon64, immediately the DW4 window collapses
and in the DW4 folder I find a new log file.
No matter the Java version I do use. I have tried 8.201, 8.231 and 8.271
It seems something related to the serial port because DW4 can be used, I mean I can mount a VDK in any drive
but when it receives any D64 message it closes the window and exits.
I attach here a few dump files for maybe someone with more DW knowledge could give it a read and maybe
could give me a hint/idea about what should be done to make it work again :-(
Thanks beforehand
LogFiles.zip
(21.14 KiB) Downloaded 354 times
Re: Drivewire4 server problems
for maybe any other user suffers that very same problem in the future ...
I have tried four different Java versions, no changes at all.
Then I have updated the serial to USB driver but no luck!
The solution has been 'downgrading' to Java jdk-8u111
Now I can work with my Netbeans and drivewire server receives commands from the D64 and
serves them correctly!!
