6809/6809E compatibility
Hello, wonderful people!
I'd like to ask about the difference between 6809/6309 and 6809E/6309E processors.
It looks like the standard and E versions have a set of pins with different functions, and the direction of the E and Q pins seem to be reversed.
I upgraded my D200 with a 6309EP, and on the other hand my D64 is running smoothly with a 6309P, and I'm not sure if it can be a problem or not.
And, if it isn't could you put a standard 6809 on a Dragon?
snarkhunter
Re: 6809/6809E compatibility
Post by snarkhunter »
According to Wikipedia, the "E" version of both processors "needs an external clock generator" (which was an internal feature of the standard version).
https://en.wikipedia.org/wiki/Motorola_6809#6809
Is this what you were looking for?
I know that, but my question is more if standard and E versions are interchangeable, and if they are not how come that I have a D64 with a standard 6309 working well.
Hi Rob!
In general the internal/external clock versions are not interchangeable so I am amazed it works at all. As you say, there are a number of pin differences but the ones that matter in the Dragon are the E and Q directions.
So in your D64 you have both SAM and CPU trying to drive the E and Q clocks i.e. not a healthy situation. My guess is that the SAM is driving much more strongly than the CPU. There's even a chance the drivers fried in the CPU shortly after power up, allowing SAM to drive the clocks. Either way, this is not something I would try myself.
Hi Stew,
Thanks for the info!
It would have been nice to have it mentioned on the datasheets...
I'll look to get a proper 6309E in order to avoid damaging anything else.
The surprising bit is that it works as if it were a completely compatible replacement.
Unless you’ve just unwittingly discovered more extreme cleverness from Hitachi… ;)
I consider it an option!
That it maybe detects an incoming clock signal and disables the internal one.
I've seen weird edge cases with several processors, but having it running without problems for more than 4 years... that would be too much to ask :mrgreen:
bluearcus
Post by bluearcus »
Where did you source the CPU? Those Chinese sellers are not shy of relabeling...
That will definitely just be a relabelled processor. Most likely a 6809E. I'm more used to getting 6809s relabelled as 6309E chips. Basically the places doing the relabelling just don't appreciate the difference between the chips.
Good thing then that nothing blew up...
