Emulator ability to print...
ade
Post by ade »
A basic question that if I did a search is no doubt find the answer to but today I'm feeling lazy!
Does anyone know if it's possible to print a basic listing from xroar to a standard pc based printer or is there a program that will covert . Cas to txt that can be copied to notepad?
Thanks in advance...
Re: Emulator ability to print...
Not directly, but you can pipe printer output through a command to achieve this: http://www.6809.org.uk/xroar/doc/xroar.shtml#Printing
ade
Post by ade »
