CoCoSDC
CoCoSDC
There is no CoCoSDC here?!?
I have two of these cool hardware... One works:
bluearcus
Re: CoCoSDC
Post by bluearcus »
Quite a few of us have CoCoSDC's... if you search on here there are quite a lot of posts about Pere's development of the Dos Plus Extender ROM!
With the SDC Explorer it is an excellent system. However, it's a bit unreliable with OS9 booting, something that I've been investigating for quite a while. Hopefully we'll get that cracked eventually, because hard-disk style OS9 use is possible with the SDC, which is a great thing to start exporing.
Re: CoCoSDC
I have one, but it doesn't get as much use as it should. Probably because it has no case, which means I have to put it away after use, else a cat will surely jump on it and snap something. They really are pretty neat, though :)
(I've still never tried the explorer)
Re: CoCoSDC
