Search function missing from Downloads section
Hi everyone!
I guess I'm not the only one that has noticed the missing search box on the Downloads section.
Thing is, I've found that the link to the Downloads section on the left side panel points to a new address:
Which has no search box.
But for those like me, that find the search box way too useful, the old Downloads page with search box can be reached here:
I know that maintaining the Archive is a daunting task, and don't want to pressure Simon, but I think the search box is a critical feature.
So, would you kindly address this issue when time allows?
Big thanks!
Re: Search function missing from Downloads section
Noted - but will have to be low priority.... Keep using the old system, I will keep it active just not preferred.
