Hacker Utility
Sarah
Hacker Utility
Post by Sarah »
This is a little utility that I created long ago and used to help find & test cheats for tape based games. It works with the original Lunar Rover Patrol, for example, finding the lives POKE 22312 quite easily. The games need to be in simple CLOADM/EXEC format (or a CLOADM loader followed by a headerless part is also supported). Sorry no instructions, however it's fairly straightforward to use. Once the game has been loaded it searches for likely POKEs and offers options to try them out or move onto the next possibility. Rinse and repeat. I just retested using Xroar Online, it seems to run okay. I expect the 'MON' option would jump to DREAMBUG if loaded in the cartridge port.
HACKER.CAS
HACKER.CAS by Sarah Burgin
(1.74 KiB) Downloaded 157 times
