Scrolling Graphics Questions
Re: Scrolling Graphics Questions
sorchard wrote: I think you can get most of the 7% improvement without having a huge program, if you copied for example 128 or 256 bytes per loop.
Hi Stew,
I have tested with 4x32 = 128 and the speed gain is not visible on screen.
The 'con' of this method is that as I need to scroll the whole screen except for a line
this means 191 files being moved (32 bytes x row)
Going up to 128 needs 191/4 = 47 times and then I have to add the three last ones
because 4 * 47 = 188
Trying to go further to 256 would imply: 8 * 23 times = 184, so I would have to add SEVEN more!
If I try to reuse the ones coded into the block, then I have to introduce test and branch, so
losing the gains ...
I think that the full unrolled version was not visibly faster, but of course it used less cycles
to be dedicated to other actions of course, but the size was a high cost!
VSDSTK3.zip
Source file
(1.6 KiB) Downloaded 738 times
Hi Pere,
One trick you can use to do the extra 3 lines is to jump into the right place in the loop at the beginning. Something like this:
  lda #48
  sta count
  bra skip
loop
  copy32
skip
  copy32
  copy32
  copy32
  dec count
  bne loop
Hi Stew,
great idea, better do it as soon as possible than waiting for the final part, wondeful indeed!
Will give it a try ...
thanks a lot
