Junior's Revenge by Dragon Data
Re: Junior's Revenge by Dragon Data
Hi guys!
I tested the build version of XRoar, and the game work ok on D32 mode but not on D64 mode, as I guess it should be.
Also tried Zephyr's patch and it also works on my D64.
In the end, the game was correctly preserved, as it does not work on a D64 without patching.
Thanks so much!
Edit:The computerware version works on the D64 right away.
xroar -trace ... | egrep '(ST|LD).*\$ff[13][0-9a-f]' reveals:
3f09| b7ff07      STA     $ff07         125aa2
3f0c| b6ff06      LDA     $ff06         135aa3
3fa4| f7ff2a      STB     $ff2a         525a8f
5792| b7ff2a      STA     $ff2a         125a8f
583b| f7ff28      STB     $ff28         525a8d
Those second numbers are the hex values EOR $A5 - which is how it's saved to tape ("copy protection", I guess!). Searching the CAS file and replacing those with the appropriate correct values (and adjusting block checksums) leads to: juniors_revenge_fixed.cas
Seems to work, but I only played it as far as the second level...
The attached version uses an updated auto-running version of my patch which also automatically detaches DOS (or any other auto-start cartridge based software) before loading the game. The game code on cassette remains unmodified and is patched only at runtime.
Junior's Revenge (1983)(Dragon Data)[h Zephyr].zip
(30.72 KiB) Downloaded 474 times
Oh, neat. Only now watched to see what your patcher does. Cool solution (and usable having the original game, of course).
snarkhunter
Post by snarkhunter »
robcfg wrote:Could someone test it on a real Dragon 32? Just to be sure.
I could not do so any longer now (and more for practical than technical reasons, actually)... but I used to play the game after purchasing it, back then! This version was rather disappointing (especially after enjoying it on a friend's ColecoVision console), but the cassette version did work fine on my Dragon 32, as far as I can remember.
