I'll generate a full rip of Pedro next week (good to have an original version too, I think), and as a note to self: also need to re-rip Tubeway Army - the version on here plays, but the "Game Over" sample is corrupt!
Nobody yet has a good rip (even a WAV) of Perilous Pit then?
Perhaps we should log all "known bad" dumps on here in some common place so we can replace them if we have them? (edit: actually I guess posts here are perfectly fine as we'll all see them anyway)
Perilous Pit .cas file problems?
Re: Perilous Pit .cas file problems?
Here's my DragonDos compatible version of PEDRO (again) but with original first loading screen restored. Also included is a fresh dump of the original game.
- PEDRO_DGNDOS.zip
- (38.69 KiB) Downloaded 676 times
Doubly excellent because my copy isn't in my tape box. Cheers!zephyr wrote:Also included is a fresh dump of the original game.
All,
If we want to keep track of good/bad dumps then can I suggest we use the Wiki so that everybody can edit a games entry to update the dump status. That way when we spot issues like this they can be tracked. You can login to the wiki with the same username and password you use for this board.
The link to the games index (by publisher) is:
http://archive.worldofdragon.org/index.php?title=Games
If you want to edit the entire entry for the game, then please use GLOVE as an example:
http://archive.worldofdragon.org/index.php?title=GLOVE
or if you just want to flag the dump status then edit the game entry and put one of the following:
[[Category:Bad_Dump]]
[[Category:Original_Dump]]
[[Category:Modified_Dump]]
The results can be seen here:
http://archive.worldofdragon.org/index. ... Categories
