Zaxxon by Steve Bjork
briza
Re: Zaxxon by Steve Bjork
Post by briza »
snarkhunter wrote:
Yes, that's the one!
Please note that, in order to run this game, you need to:
- Open the proper ".VDK" file first (cf above),
- Then load the game (i.e. LOAD "ZAXXON.BIN")
- Then RUN "UNBOOT.BIN",
- Then EXEC15520 (... I saved you the trouble of finding the proper EXEC vector!)
It's only in B&W, but I don't know whether or not there ever was any colour option available for this game. And this is indeed the Steve Bjork version, running without any trouble on the Dragon.
Hi Guys.
Zaxxon was done in color on the coco. But it was using the Pmode4(Black/White mode) artifact trick to achieve the colors. Only way to see the colors is using a emulator or getting your hands on a TV that does NTSC format. This is what I do to see artifact colors on my coco 3 Ntsc unit I got from America. Based in Australia means we also cannot see a lot of the games in color.
laters
Briza
samplefiend
Post by samplefiend »
hi all,
is it possible to get this version of Zaxxon as a .cas or .wav file so I can see if it works on my hardware Dragon please? I used to have this on a C-90 cassette back in the day and didn't realise it wasn't an actual Dragon game. It was brilliant though and I'd love to play it again. can i extract it from the vdk file and how would I go about it? i found a version that is in .pak format but it seems to be in colour on the emulator i tried it with which doesn't look as good as the b&w version here and I don't know how to change it into a wav either. d'oh!
any help greatly appreciated from a newbie.
love n hugs,
craig xxx
snarkhunter
Post by snarkhunter »
... Here it is!
And just in case you should ever need the m/c vectors in order to re-save this game, these are as follows : 15520, 32440, 15520
(CLOADM / EXEC to load, then run, the game ; running this game in "DOS" mode requires running UNBOOT first)
Best regards,
Lionel
ZAXXON.CAS
(17.44 KiB) Downloaded 582 times
samplefiend
hi lionel,
many many thanks for uploading the Zaxxon file i requested. I've just loaded it up on my Dragon 32 and it worked a treat. All i need to remember now is to Press Q instead of 1 to get the game going. Hours of fun ahaead of me tonight thanks to you!
cheers mate
craig xxx
