Proposing CAS extension: Cue data
Re: Proposing CAS extension: Cue data
I've done a:
And when I list the branches, I only get:
*master
Is that ok? I have to say that I haven't use git much because I'm more the Mercurial type, but they should work pretty much the same.
git branch on its own only lists local branches. Use git branch -a to see the remote ones too. If you git checkout cascue, it should set up a local branch tracking the remote you cloned.
Edit: ah, turns out I'd messed up calculating timing in bin2cas, the error tracking in cas2wav wasn't really an issue.
Dropped a few examples, and the conversions by cas2wav, in here:
http://www.6809.org.uk/tmp/da/cuetest/
I've finally updated the CAS file format definition with the Cue data extension format, as it's now supported on Xroar.
You can read it here.
