Hello everyone!
I'm programming a nice utility for converting wav files to cas files, and I'm wondering what are the frequencies of the 0 and 1 waves.
For the coco, they are 1200hz for 0 and 2400hz for 1, but most dragon tapes are more like 1000hz and 2000hz. Can anyone confirm the right values?
Also, I was wondering if using the PZX format would be a good idea, as it keeps a better representation of the original wave data, and would allow several copy protected games able to be run other than using a wav file.
Dragon tape pulse frequencies
- rolfmichelsen
- Contact:
Re: Dragon tape pulse frequencies
Hmmm... Inside the Dragon claims the same frequencies, 1200 Hz for a 0 and 2400 Hz for a 1. I guess this isn't really that accurate, but the difference between the two frequencies is so significant that detection is possible anyway. If I recall correctly, each bit is encoded as a full waveform of the given frequency, so just detecting the time between 0 crossings should be sufficient.
Ok, thanks!
