How to burn .VDK files to floppy disk to use on Dragon
Stig
Post by Stig »
I recently got my Dragon disk drive working and I am looking for a way to put downloaded .VDK files on to actual floppy disks to use on my Dragon.
I have tried searching the forums but can't find any info. Is it possible for me to do this ?
I have an old win 95 PC that I could hook the floppy drive up to but not sure if that is a good idea or not ?
Any help would be appreciated
Thanks
John
KenH
Re: How to burn .VDK files to floppy disk to use on Dragon
Post by KenH »
The easiest way to transfer VDK files to a Dragon with floppy drive would be using pere's V2FLO dweeb and tormod's drivewire adapter.
V2FLO viewtopic.php?f=5&t=4968#p12107
Drivewire adapter viewtopic.php?f=6&t=4854
John, if you've got a 5.25" drive in your PC you can use VCOPY.EXE to copy .VDK files to floppy. I'm guessing that it's probably better to buy a 5.25" drive to put in your PC rather than trying to attach the Dragon drive, but I have no experience in this matter so I may be wrong.
TomEG
Post by TomEG »
I second the uDW/V2FLO route. It works very well.
I downloaded every single .vdk file in the archive, and saved them to a microSD card. Put the card in tormod's uDW and used pere's V2FLO dweeb to copy them to floppys.
I also have tormods DWLOAD ROM installed, so then it's just a matter of putting the floppy in the drive, and type:
DLOAD"V2FLO""filename.vdk"
or even simpler:
Tom
For those without DriveWire, I recommend Samdisk, Omniflop or even the HxC software. They all should work on a moder PC with a 5.25" drive.
If you have an older PC with a BIOS that can support 720K drives then you *may* be able to connect the drive from the dragon and use VCOPY.EXE in MS-DOS (or Windows 95/98 DOS) to read/write disks. If I recall you need to change a jumper on the drive itself to switch into PC/XT mode rather than the older shugart mode used by the Dragon and older 8-bit micros - thus its easier to follow this route if you can get hold of a 720Kb PC drive.
As the others have stated above, we now have a number of ways of getting the images onto a dragon and from there written to disk by the dragon. One method I have used is to connect my HxC as Drive 1 and simply duplicate the disks from virtual to physical.
Stig
Post by Stig »
Thanks for all the help guys !
I'm not sure which method I will use. Getting an old floppy drive for my old PC will probably be the cheapest option but maybe not the most reliable lol
TomEG
Post by TomEG »
I forgot to say that when using he uDW route, all .vdk's will have to be "padded" to a filesize of a multiple of 256. But there's tool for that too.
KenH
Post by KenH »
Stig wrote:Thanks for all the help guys !
The advantage with the drivewire adapter option is that it has many uses beyond just copying files to floppy.
And I don't think you can find much cheaper options than the standard adapter that is $18 + shipping
viewtopic.php?f=6&t=4270
