Dragon vs. CoCo BASIC
I start to add CoCo support in DragonPy BASIC Editor... So i need the CoCo Color BASIC tokens...
I found: http://sourceforge.net/p/toolshed/code/ ... ms/bas.asm and convert it to a Python dictionary: https://github.com/jedie/DragonPy/blob/ ... _tokens.py
Then it interests me, to compare them with the Dragon token table... So i add a simple script to generate a Wiki table, here: http://archive.worldofdragon.org/index.php?title=Tokens
Re: Dragon vs. CoCo BASIC
Hm... I played with some BASIC Scripts now with the CoCo Color BASIC 1.3 and found, that hex values doesn't work :(
PRINT &H100
results in a SN ERROR...
So my Hex Viewer programm (See viewtopic.php?f=4&t=4348&p=9440&hilit=hex+viewer#p9437 ) doesn't work, because i do this:
170 INPUT "START ADDRESS IN HEX &H"; ADDR$
180 EA = VAL("&H"+ADDR$)
EA is always 0
Is this "normal" ?
jedie wrote: Is this "normal" ?
Yes. You will need to use the combined COLOR BASIC and EXTENDED COLOR BASIC ROMs for Hex.
I try to startup XRoar with Extendet color BASIC, but doesn't work. I do this:
xroar -keymap de -kbd-translate -default-machine coco -bas 'Color Basic v1.3 (1982)(Tandy).rom' -extbas ExtendedColorBasic1.1.rom -nodos
Output is this:
Module init: GTK+-2 UI
Module init: GTK+-2 file requester
Module init: GtkGLExt video
Module init: OSS audio
ERROR: OSS: failed to open device
Module init failed: OSS audio
Module init: Pulse audio
	16-bit signed little-endian, stereo, 48000Hz
	10ms (512 samples) buffer
Module init: GTK+-2 keyboard input
	Selecting 'de' keymap
Machine: Tandy CoCo (PAL)
Loading ROM: ExtendedColorBasic1.1.rom
Loading ROM: Color Basic v1.3 (1982)(Tandy).rom
	32K mode BASIC CRC = 0x56c13bab
	BASIC CRC = 0xd8f4d15e
	Extended BASIC CRC = 0x1e425113
But it's seems that's only Color BASIC 1.3:
The ROM files are from:
http://archive.worldofdragon.org/archiv ... ndy%29.zip
The ExtendedColorBasic1.1.rom seems to be a collection, because i see this string in there:
EXTENDED COLOR BASIC 1.1
COPYRIGHT (C) 1982 BY TANDY
UNDER LICENSE FROM MICROSOFT
COLOR BASIC 1.2
(C) 1982 TANDY
DISK EXTENDED COLOR BASIC 1.1
COPYRIGHT 1982 BY TANDY
In this order.
So i didn't need the 'Color Basic v1.3 (1982)(Tandy).rom' ?!?
Ah... If you search for "MESS BIOS images" you will find e.g.: http://mess.oldos.net/
There are many, many ROM files. In coco2b.zip are two files: bas13.rom and extbas11.rom...
With:
xroar -keymap de -kbd-translate -default-machine coco -bas bas13.rom -extbas extbas11.rom -nodos
it starts with:
Loading ROM: extbas11.rom
Loading ROM: bas13.rom
	Extended BASIC CRC = 0xa82a6254
And i see:
OK
?&H400
 1024
OK
:D
jedie wrote:So i add a simple script to generate a Wiki table, here: http://archive.worldofdragon.org/index.php?title=Tokens
I updated the script with https://github.com/jedie/DragonPy/commi ... a4aeae4846
and update the Wiki page to list CoCo tokens from "Color BASIC 1.3" and "Extended Color BASIC 1.1"
I used the information from:
and
http://sourceforge.net/p/toolshed/code/ ... extbas.asm
jedie wrote:Ah... If you search for "MESS BIOS images" you will find e.g.: http://mess.oldos.net/
All CoCo and Dragon system ROMs have been available from the Uploads section since 2011.
viewtopic.php?f=7&t=555
