plug "Cassette recorder socket" into PC Soundcard ?
Is it possible to plug the cassette in/out with a simple, passive cable into a PC Soundcard?
The pinouts have i found here: http://dragon32.info/info/pinouts.html#tape
Somewhere i found a "cassette to iPhone" guide and there was two resistors. Only for "volume" adjust?
Re: plug "Cassette recorder socket" into PC Soundcard ?
You don't need resistors for normal sound cards, that's an "iThing". Simple, passive cable is fine.
Thanks for the info.
Yes, a simple cable works here ;)
Cool, i can read/write my BASIC programm on PC ;)
