Restore to a line number
This routine will allow you to restore to a line number. The machine code routine is position independent, and DOS compatible.
10 'RESTORE-LINE-NUMBER V1.0
20 'FOR THE DRAGON 32/64
30 'BY STEPHEN J WOOLHAM
40 '***************************
50 'BASIC EXAMPLE PROGRAM
60 '***************************
70 MC$="DCD1DD2B9E19BD840325037E85167E8605"
80 X=1:FOR I=1004 TO 1020:POKE I,VAL("&H"+MID$(MC$,X,2)):X=X+2:NEXT
90 '
100 'LN = LINE TO RESTORE TO
110 '
120 LN = 200
130 POKE209,VAL("&H"+LEFT$(HEX$(LN),LEN(HEX$(LN))-2))
140 POKE210,VAL("&H"+RIGHT$(HEX$(LN),2)):EXEC1004
200 DATA A,B,C
Here's the same routine for Tandy Color Computer models 1, 2, and 3.
20 'FOR TANDY COLOR COMPUTER
30 'MODELS 1, 2, AND 3
40 'BY STEPHEN J WOOLHAM
50 '***************************
60 'BASIC EXAMPLE PROGRAM
70 '***************************
80 MC$="DCD1DD2B9E19BDAD0525037EADE67EAED2"
90 X=1:FOR I=1004 TO 1020:POKE I,VAL("&H"+MID$(MC$,X,2)):X=X+2:NEXT
100 '
110 'LN = LINE TO RESTORE TO
120 '
130 LN = 200
140 POKE209,VAL("&H"+LEFT$(HEX$(LN),LEN(HEX$(LN))-2))
150 POKE210,VAL("&H"+RIGHT$(HEX$(LN),2)):EXEC1004
200 DATA A,B,C
Re: Restore to a line number
What do you mean when you say "restore to a line number"?
The Dragon's RESTORE command can only restore the data pointer to the start of a BASIC program. You can't do the following.
10 RESTORE 200:READ A$
20 RESTORE 300:READ B$
30 RESTORE 100:READ C$
40 PRINT A$;" ";B$;" ";C$
50 END
100 DATA THREE
200 DATA ONE
300 DATA TWO
Here's a quick example of how the routine can be used.
10 MC$="DCD1DD2B9E19BD840325037E85167E8605"
20 X=1:FOR I=1004 TO 1020:POKE I,VAL("&H"+MID$(MC$,X,2)):X=X+2:NEXT
30 LN=200:GOSUB10000:READ A$
40 LN=300:GOSUB10000:READ B$
50 LN=100:GOSUB10000:READ C$
60 PRINTA$;" ";B$;" ";C$
70 END
100 DATA THREE
200 DATA ONE
300 DATA TWO
10000 POKE209,VAL("&H"+LEFT$(HEX$(LN),LEN(HEX$(LN))-2))
10010 POKE210,VAL("&H"+RIGHT$(HEX$(LN),2)):EXEC1004
10020 RETURN
Right, I get it now, thanks.
Here's an alternative routine which utilises the CLS command to greatly improve execution speed of the BASIC program. The machine code routine is position independent, and DOS compatible.
10 'RESTORE-LINE-NUMBER V2.0
70 DATA 30,8D,0,1C,BC,1,A1,27,16,B6,1,A0,A7,8D,0,35,FC,1,A1,ED,8D,0,2F,86,7E,B7,1,A0,BF,1,A1,39,34,1,8C,81,94,26,1C,81,BC,26,18,9D,9F,9D,A5,BD,86,9A,35,11,DC,2B,9E,19,BD,84,3,25,3,7E,85,16,7E,86,5,35,1,39,39,39
80 CLEAR200,32695
90 FOR I=32696 TO 32767:READ MC$:X=VAL("&H"+MC$):CSUM=CSUM+X:POKEI,X:NEXT
100 IF CSUM<>6866 THEN CLS:PRINT"ERROR IN DATA LINE":END
110 EXEC32696
120 '
130 ' TEST ROUTINE
140 '
150 CLSTO2000:READ A$
160 CLSTO3000:READ B$
170 CLSTO1000:READ C$
180 CLS:PRINTA$;" ";B$;" ";C$
190 END
1000 DATA THREE
2000 DATA ONE
3000 DATA TWO
80 DATA 30,8D,0,1C,BC,1,A1,27,16,B6,1,A0,A7,8D,0,35,FC,1,A1,ED,8D,0,2F,86,7E,B7,1,A0,BF,1,A1,39,34,1,8C,AB,A3,26,1C,81,A5,26,18,9D,9F,9D,A5,BD,AF,67,35,11,DC,2B,9E,19,BD,AD,5,25,3,7E,AD,E6,7E,AE,D2,35,1,39,39,39
90 CLEAR200,32695
100 FOR I=32696 TO 32767:READ MC$:X=VAL("&H"+MC$):CSUM=CSUM+X:POKEI,X:NEXT
110 IF CSUM<>7426 THEN CLS:PRINT"ERROR IN DATA LINE":END
120 EXEC32696
130 '
140 ' TEST ROUTINE
150 '
160 CLSTO2000:READ A$
170 CLSTO3000:READ B$
180 CLSTO1000:READ C$
190 CLS:PRINTA$;" ";B$;" ";C$
200 END
1000 DATA THREE
2000 DATA ONE
3000 DATA TWO
This routine modifies the Dragon's original RESTORE command to optionally accept line numbers. The machine code routine is position independent, and DOS compatible.
10 'RESTORE-LINE-NUMBER V3.0
70 DATA 30,8D,0,1C,BC,1,7A,27,16,B6,1,79,A7,8D,0,38,FC,1,7A,ED,8D,0,32,86,7E,B7,1,79,BF,1,7A,39,34,7,81,90,26,20,10,9E,A6,9D,9F,9D,A5,27,14,BD,86,9A,35,17,DC,2B,9E,19,BD,84,3,25,3,7E,85,16,7E,86,5,10,9F,A6,35,7,39,39,39
80 CLEAR200,32692
90 FOR I=32693 TO 32767:READ MC$:X=VAL("&H"+MC$):CSUM=CSUM+X:POKEI,X:NEXT
100 IF CSUM<>6916 THEN CLS:PRINT"ERROR IN DATA LINE":END
110 EXEC32693
120 '
130 ' TEST ROUTINE
140 '
150 RESTORE2000:READ A$
160 RESTORE3000:READ B$
170 RESTORE1000:READ C$
190 END
1000 DATA THREE
2000 DATA ONE
3000 DATA TWO
N/B This routine is NOT compatible with the CoCo Break Disable v1.0.
80 DATA 30,8D,0,7,9C,A9,27,2,9F,A9,39,81,8F,26,2B,34,12,30,1,9C,A6,26,21,1F,12,9D,9F,9D,A5,27,16,BD,AF,67,DC,2B,9E,19,BD,AD,5,25,7,BD,AD,E6,35,12,4F,39,7E,AE,D2,10,9F,A6,35,12,7E,AA,1A
90 CLEAR200,32706
100 FOR I=32707 TO 32767:READ MC$:X=VAL("&H"+MC$):CSUM=CSUM+X:POKEI,X:NEXT
110 IF CSUM<>5927 THEN CLS:PRINT"ERROR IN DATA LINE":END
120 EXEC32707
130 '
140 ' TEST ROUTINE
150 '
160 RESTORE2000:READ A$
170 RESTORE3000:READ B$
180 RESTORE1000:READ C$
200 END
1000 DATA THREE
2000 DATA ONE
3000 DATA TWO
