Interrupt driven real-time-clock
Here's an interrupt driven (IRQ) real-time-clock that you can use in your own BASIC programs. The machine code routine is position independent and DragonDOS compatible.
10 ' INTERRUPT DRIVEN
20 ' REAL-TIME-CLOCK V1.0
30 ' BY STEVE EVANS
40 ' 30TH MARCH, 2012
50 '
60 'LOCATION 252 = IRQ COUNT
70 'LOCATION 253 = SECONDS
80 'LOCATION 254 = MINUTES
90 'LOCATION 255 = HOURS
100 '
110 CLEAR200,32691:START=32692
120 FOR I=0 TO 75:READ A$:X=VAL("&H"+A$):CH=CH+X:POKE START+I,X:NEXT
130 IF CH<>7542 THEN PRINT"ERROR IN DATA LINES.":END
140 '
150 'CHANGE "POKE START+28,49"
160 'TO "POKE START+28,59" FOR
170 '60HZ TANO DRAGON 64
180 '
190 POKE START+28,49:EXEC START:END
200 DATA 1A,50,30,8D,0,12,BC,1,D,27,A,FC,1,D,BF,1,D,ED,8D,0,35,1C,AF,39,96,FC
210 DATA 4C,81,31,25,28,F,FC,96,FD,4C,81,3C,25,1B,F,FD,96,FE,4C,81,3C,25,E,F,FE
220 DATA 96,FF,4C,81,18,25,1,4F,97,FF,20,A,97,FE,20,6,97,FD,20,2,97,FC,7E,9D,3D
Interrupt_driven_clock_v10.zip
(1.99 KiB) Downloaded 750 times
Re: Interrupt driven real-time-clock
Nice work!
I guess the resolution of the timer would be 50 or 60hz, or does the dragon have a more frequently used interrupt?
No, only the 50Hz (PAL) or 60Hz (NTSC) IRQ interrupt.
The Dragon/CoCo IRQ can be enabled or disabled from within a BASIC program as follows:
Disable IRQ = POKE65283,PEEK(65283)AND254
Enable IRQ = POKE65283,PEEK(65283)OR1
Enable IRQ = SOUND1,1 etc
The IRQ is used by the BASIC interpreter's PLAY, SOUND, and TIMER routines. Any attempt to use the PLAY command when the IRQ is disabled will result in the computer freezing.
rolfmichelsen
Post by rolfmichelsen »
robcfg wrote:I guess the resolution of the timer would be 50 or 60hz, or does the dragon have a more frequently used interrupt?
Normally, IRQ is generated from the video field sync signal at a 50 Hz frequency. It is possible to reconfigure the PIA to generate IRQ interrupts from the horizontal sync as well, with a frequency of 15,7 kHz. Only problem is that servicing that many interrupts will eat most of the CPU clock cycles, but if you want to pay the price of a real high resolution timer, the possibility is there.
zephyr wrote:Here's an interrupt driven (IRQ) real-time-clock that you can use in your own BASIC programs. The machine code routine is position independent and DragonDOS compatible.
Can you post the assembly code from this?
jedie wrote:Can you post the assembly code from this?
The original source code for this routine has been deleted.
You ok with me posting a disassembly?
sixxie wrote:You ok with me posting a disassembly?
Is this a reply to jedie or myself? My answer would be yes. :)
zephyr: heh, your post originally, so was asking you. Cool. Here:
		if	!NTSC
ticks_per_sec	equ	$31
		else
ticks_per_sec	equ	$3b
		endif
ticks		equ	$fc
seconds		equ	$fd
minutes		equ	$fe
hours		equ	$ff
		org	$7fb4
		orcc	#$50
		leax	irq_rtc,pcr
		cmpx	>$010d
		beq	no_init
		ldd	>$010d
		stx	>$010d
		std	old_handler,pcr
no_init		andcc	#$af
		rts
irq_rtc		lda	<ticks
		inca
		cmpa	#ticks_per_sec
		bcs	st_ticks
		clr	<ticks
		lda	<seconds
		inca
		cmpa	#$3c
		bcs	st_seconds
		clr	<seconds
		lda	<minutes
		inca
		cmpa	#$3c
		bcs	st_minutes
		clr	<minutes
		lda	<hours
		inca
		cmpa	#$18
		bcs	st_hours
		clra
st_hours	sta	<hours
		bra	done
st_minutes	sta	<minutes
		bra	done
st_seconds	sta	<seconds
		bra	done
st_ticks	sta	<ticks
done		jmp	>$9d3d
old_handler	equ	done + 1
In case formatting breaks: http://www.6809.org.uk/tmp/da/irq_rtc.s
