as promised, you will find here a zip for each machine that contain the 141 games that have been converted.
I hope this will help users that have found this thread a few weeks ago to download all of them in a big pack.
I have included a text file that shows the used keys for each game and another text file explaining how to use the virtual disks of this series.
POLL: I have created a poll so that you could tell us what are the games you like most from these 141.
I will be updating here the Top Ten every week.
You will access that poll here:
https://goo.gl/forms/gwvd5hXPS1kVIfOa2
UPDATE: 2019/03/19 - I delete this pack because there have been a few changes in 6 games.
In order to have all data together I will be updating this 'only' thread from now on
viewtopic.php?f=7&t=5921
AGD converted games: Full Pack and POLL (OBSOLETE)
Re: AGD converted games: Full Pack and POLL
I love all these AGD game conversions.
WELL DONE!
I hope this really isn't the "FINAL" pack, and you have the time to convert some more in the future.
There are at least 40 other AGD games i am aware of.
i can provide the links when or if you are interested.
WELL DONE!
I've definitely not got through all of them, so I couldn't possibly rate the top few, but I've started putting together some mini-reviews for my own reference...
http://www.6809.org.uk/tmp/da/agd-reviews.txt
Good idea, we would appreciate the links to those games, so please share them with us!
Anyway we have been forced to 'park' some 35 games that, by now, cannot be converted with the current version of
the convert.exe program that converts the .sna files into macro files with extension .AGD most probably due to the
fact that they were created with AGD versions that are no more supported by the current convert version.
A few of them do convert but they do not work properly, so most probably some commands are missinterpreted and
so converted to the wrong ones ...
No doubt some of those 35 will be in this pack.
hope you mange to convert a few.
- agd.zip
- (1.62 MiB) Downloaded 685 times
Thanks a lot. Just downloaded the zip
We will see if there are any no yet downloaded in this zip.
Counting the ones we had set aside, I foud in fact 28 not converted and 12 with problems after converting, so 40 instead of 35 as I had said.
This is the list of games you packed into the zip file and their current situation
ChopperDropV1.tzx NEW
ChopperDropV2.tzx NEW
ChunkZone.tap Unable to convert it
DarkCastle.tap Unable to convert it
donkey-kong-jr Unable to convert it
DonkeyKongJrII.z80 Released in Pack #08
DonkeyKongJrII_WithTimer.z80 NEW. a variant of previous?
DonkeyKongReloaded.tap Unable to convert it
DonkeyKongReloadedAgain.z80 Unable to convert it
ElonMWithJetpack.tzx Converted wrongly. Bad behaviour
FindTheGreenRoom.tap NEW
FunkyFungus(EN).tap NEW
HeroesRescue.tap NEW
KydCadetII-TheRescueOfPobbleflu.tap Unable to convert it
KydCadetV1.2.tap NEW
LupoAlberto.tap Unable to convert it
MonkeyJ-TheTreasureOfTheGoldTemple.tap Converted wrongly. Bad behaviour
montys-honey-run Released in Pack #12
MontysLastStrike.tap isn't the same than next one?
MontysLastStrikeAChristmasJob.tap Released in Pack #03
Mystery(128K).tap 128K games don't fit in 6809 64K machines
OhLaLa.tap Unable to convert it
PengoQuest.tap Unable to convert it
PickaxePete.tap Converted wrongly. Bad behaviour
PitfallIII-WrathOfKingcrock.tap Unable to convert it
R2-D2.tap Unable to convert it
RaidersOfTheLostArk(Cursor).tap NEW
RaidersOfTheLostArk(QAOP).tap Converted wrongly. Bad behaviour
RobotSanta.tap NEW
SetoTaishoVsYokai(EN).tap Unable to convert it
Sophia2(EN).tap 128K games don't fit in 6809 64K machines
Sophia2.tap same than previous one
SpaceDisposal.tap Unable to convert it
Squares.tap Unable to convert it
STARS(Gumi).tap Unable to convert it
Terrapins_demo.tap Released in Pack #14
TheAmethystDagger.tzx Converted wrongly. Bad behaviour
TheIncredibleShrinkingProfessor.tap Released in Pack #02
TheLostIsland.tap Unable to convert it
ThreeOctopuses_eng.tap Unable to convert it
ToofyInFanLand.tap Unable to convert it
ToofysWinterNutsV1.2.tap Unable to convert it
Trooper-Point5V1.2.tap Unable to convert it
ZbylutOwrzodzienWKamiennymKurwa ...
ZajebanymCzarcimKregu_2.tap Unable to convert it
Anyway I will give a try at all of them (if not yet released) for maybe the version you have uploaded could be better than the one we tested
Thanks a lot
