Dragon Convert for MS-DOS (Source)
Sarah
Post by Sarah »
DRAGON CONVERT (DC) is a utility for converting files from WAV/VOC/BIN/BAS/DGN/CAS to CAS/DGN/BAS/WAV format.
It runs under MS-DOS or Windows 95/98/NT and has recently celebrated its 20th anniversary! :lol:
There were a couple of posts recently asking for the source code, so I've now published it here:
http://emulator.org.uk/dc.c
The source is written for Borland Turbo C. If you wish to compile DC then you'll also need my long filename library which can be found here:
http://emulator.org.uk/com/lfn-100.zip
Also attached below:
dc-401.zip
(7.99 KiB) Downloaded 330 times
lfn-100.zip
(12.87 KiB) Downloaded 310 times
Copyright Notice
Dragon Convert (DC) is copyright 1993-2013 Sarah Burgin
All rights reserved. Commercial use prohibited.
