Ikon Ultradrive Dragonfly TOS V2.3
bluearcus
Post by bluearcus »
Later version of the Tape Operating System for the Ikon Ultradrive.
Archive currently has 1.3, this is 2.3
Ikon Ultradrive Dragonfly ROM V2_3.zip
(3.15 KiB) Downloaded 170 times
Re: Ikon Ultradrive Dragonfly TOS V2.3
Thanks a lot!
Did you manage to get a tape working? I couldn't format the tape on the unit I scanned and dumped.
bluearcus
Post by bluearcus »
Tape control and reading works fine on the existing media I got with the drive, but I've not tried any write commands yet as I need to get some fresh blank media, hopefully soon.
I'm actually quite curious to see if the tapes can be transferred to a modern using an old recording device that uses the same tape format, in order to see how the data is actually stored.
bluearcus
Post by bluearcus »
My drive isn't registering Write Protect status properly, so I can't do any write commands at the moment. Some hardware debugging required (and disassembly of the ROM for clues...)
bluearcus
Post by bluearcus »
Ah, yes it is. Details on the main Ikon Ultradrive thread.
Problem worked out by reference to the Philips mechanism technical manual, which I've uploaded here now too.
Philips-MDCR_Service-Manual.zip
(2.12 MiB) Downloaded 167 times
Nice! Thank you for uploading it here!
Would you mind uploading it again?
It seems you zipped a html file instead of the intended pdf file... :mrgreen:
bluearcus
Post by bluearcus »
Hopefully fixed now. Stupid 7-zip, should have done it on my linux machine.
That's more like it, thanks!
