Moon Cresta
heatsink128
Moon Cresta
Post by heatsink128 »
Am trying to get the moon cresta .wav to load on my real 32 with no success, the title screen goes up but then I either goe nothing more or an i/o error. Have gotten everything else I have tried(25+ games) to load no worries except this one. Am burning the .wav files as audio to CD then loading via a personal CD player. Anyone else have problems with this game?
Advice appreciated, I am using BURN on Mac OSX to make the discs BTW.
Best regards,
Chris
Re: Moon Cresta
Afraid to say I just played out the WAV from this site into a real Dragon, and it loaded fine. Took ages, mind - it's gapped for some reason.
Check your burn? Make sure it sounds like data and is 5:49 long.
Edit: Oh, and be sure there were no transcode steps between the WAV and the burn - if for some reason it got converted to and from MP3 en-route, that could mess things up.
Edit2: No idea how likely it is to have it, but any automatic level control on your playback device should be disabled if possible.
heatsink128
Re: Moon Cresta
Thanks for the advice, still no luck I'm afraid. Going to try and copy it too a tape cassette and load it with my trusty old Radio shack data recorder, think I can get more volume than with the CD player.
Re: Moon Cresta
Have you tried hooking the audio output (either speaker or headphone socket) of your Mac to your Dragon and using the Mac as the 'tape' player?
