Would it work (and be reliable) if I were to solder a 28 pin IC socket directly onto the legs of an existing board mounted ROM chip, seat a 27C128 EPROM in the socket, and disconnect Vcc (pin 28) from the original ROM chip?
Would this method safely disable the original ROM chip, and give me a reliable working ROM via the top mounted EPROM chip?
Stacking ROM chips?
- rolfmichelsen
- Contact:
Re: Stacking ROM chips?
I'd rather disconnect the original Chip Enable signal, at pin 20, by wiring that to 5V. This is the well-defined way of putting the IC "to rest".
Is it OK to simply wire pin 20 directly to Vcc, or does it need to go through a resistor?
Is that all I need to do to make the stacked EPROM work reliably?
- rolfmichelsen
- Contact:
Pin 20 can go directly to Vcc. That should do the trick.
